Hi,
Not sure this is the right place to ask but trying anyway - i'm trying to conduct some experiment of shooting using my cellphone (Samsung s10e) a 10min video of a wheel first with no movement at all, then another 10min video with same posture and conditions just with the same wheel turning - i'm using a FHD 1920x1080 60fps + h.265 feature setting and im expecting to get different results in terms of the generated files sizes, and for some reason they are the same ~1.09GB...shouldnt i expect bigger size on the moving video? what am i missing?
can you elaborate a bit? doesnt adding moving objects results in bigger file size generation?doesnt it cause the compression engine to send more data because more is changing in each frame? if i have a street camera transmitting its data to a cloud, if the street is empty vs packed with moving cars wont i get a bigger file for the latter?
Thanks! -
I don't know for sure how it was encoded. I was just providing one scenario where they could both wind up the same size. They could even have ABR or VBR encoding if the average bitrates were the same. Those would wind up the same size also. Have you checked the 2 versions in MediaInfo?
doesnt adding moving objects results in bigger file size generation? -
[Attachment 54728 - Click to enlarge]
what should i look in MediaInfo that will explain this? -
There is only one thing which determines file size: bitrate.
Frames per second (fps) doesn't matter. 24 fps and 60 fps will produce the same files size if you encode them both at the same bitrate.
Resolution doesn't matter. SD, HD, and 4K will all produce the exact same file size if encoded at the same bitrate.
Video content doesn't matter. A static shot of a building, taken from a tripod will produce the same file size as hand-held footage of a stock car race.
People get confused because some software uses a "constant quality" encoder where the encoder does indeed look at the content of the video, and where there is lots of motion, it will increase the bitrate, thus producing a larger file size. However, I'm not sure any video camera has such an encoder because to work correctly, it has to be able to look at multiple frames to know how much motion is going on. This takes a huge amount of memory, CPU power, and time, and would be exceedingly difficult to do in real time inside a video camera or cell phone.
Is there a compression sweetspot?
By Chauceratemyhamster in forum Video ConversionReplies: 4Last Post: 8th Jul 2020, 09:03 -
Volume compression
By Aludin in forum AudioReplies: 6Last Post: 22nd Jul 2019, 11:16 -
Compression variances
By Del Greenwell in forum Video ConversionReplies: 4Last Post: 3rd Nov 2018, 04:58 -
Magic video compression
By Megafox in forum Newbie / General discussionsReplies: 3Last Post: 6th Feb 2018, 14:58 -
Compression with VD
By Tafflad in forum Newbie / General discussionsReplies: 18Last Post: 7th Feb 2016, 17:17
