Hello, I have a lg-dp132 and another lg-dp132h, both region 1, I have tried almost all the fixes to make it region free with no result, finally I bought a cd on eBay, when I put it on the tray it said check disc, it happened to me with other cd and dvd that I have tried, please any suggestion, thank you for your help
	you've tried all these hacks, correct ?? - https://www.videohelp.com/dvdhacks?dvdplayer=lg-dp132&hits=50&Search=Search
	Hello,
 Thank you for your reply, yes I tried all the hacks in the link that you posted, but I still have not had results, please is there another way to solve this situation? Thank you very much for your help.
	hello,
 where can i find a firmware for lg dvd dp132 and lg dvd dp132h? thank you for your reply
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
