I bought this player because it is advertised as "it will play virtually every Blu-ray, DVD, and audio CD format" and surprise! it doesn't play my zone B blu-rays. There is no mention of zones not in the player nor in the manual. I've realized that at least it plays region 2 and 1 DVDs. I called technical support and they say there is no workaround to make it multi zone. Anyone familiar with this player? Thanks.
Results 1 to 9 of 9
there are region hacks for denon dvd players - https://www.videohelp.com/dvdhacks?dvdplayer=Denon+DN&hits=50&Search=Search
so you might try them to see if they'll work on your player. -
Thanks for the link. I have been able to get into Factory Mode just introducing clear-1-4-7 in the home menu. In the factory mode I’m able to choose DVD region with OK button but it doesn’t work for BD region. Anybody any idea?
most dvd players only have hacks for the dvd side of the player, the Blu-ray side is still locked.
if you want a truly region free dvd /Blu-ray player then get one from here - https://www.220-electronics.com/ -
Buy a different Bluray player - one that is actually multi-region ($$).
Scott -
Have you tried contacting Denon Professional Support? https://www.denonpro.com/support
https://www.denonpro.com/index.php/products/browse3/category/video-media-players
Maybe they have a firmware update? -
I finally found a way to make this Denon player multi region. It's easy to install and requieres no soldering. I tested it myself and it works great. Take a look to RattleByte multi region kit: https://www.rattlebyte.com/Shop.php?lang=en&action=select_model&model_id=288
Yep, most of the players need soldering but this Denon and the Tascam don't. I was lucky because I have no soldering skills. Anyway, I really recomend this kits.
How to get 5.1 playback via Denon receiver
By Adrian Hepker in forum Media Center PC / MediaCentersReplies: 7Last Post: 8th Sep 2021, 01:24 -
Denon/MPC-hc Help
By forsure in forum Newbie / General discussionsReplies: 7Last Post: 16th Apr 2020, 14:42 -
Problems with Denon x4300
By Track34 in forum Newbie / General discussionsReplies: 8Last Post: 30th Apr 2019, 23:47 -
How to make Philips DVP2902/F7 multi region code zone free
By aMe in forum User guidesReplies: 4Last Post: 30th May 2018, 10:55 -
iPod locking up on Denon
By mlmiller707 in forum ComputerReplies: 0Last Post: 7th Nov 2015, 06:46
