I am trying to Convert a mkv video, but both the simple x264 launcher and the virtualdub show me the error of cannot load a 64 bit in dll 32 bit ffms.dll
Then I delete the file from the 32-bit plugins folder, and it gives me another error called: there is no function named ffvideosource
I have used the avsinfotool and the result is this:
Code:[OS/Hardware info] Operating system: Windows 10 (x64) (Build 18363) CPU: AMD Ryzen Threadripper 3960X 24-Core Processor / Threadripper (Castle Peak) MMX, MMXEXT, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, FMA3, RDSEED, ADX, AVX, AVX2 24 physical cores / 48 logical cores [Avisynth info] VersionString: AviSynth+ 3.6.1 (r3300, 3.6, x86_64) VersionNumber: 2.60 File / Product version: 3.6.1.0 / 3.6.1.0 Interface Version: 8 Multi-threading support: Yes Avisynth.dll location: C:\Windows\SYSTEM32\avisynth.dll Avisynth.dll time stamp: 2020-06-19, 20:05:14 (UTC) PluginDir2_5 (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64 PluginDir+ (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64+ [C 2.5 Plugins (64 Bit)] C:\Program Files (x86)\AviSynth+\plugins64\ffavisynth.dll [1.3.4533.0] [C++ 2.5 Plugins (64 Bit)] C:\Program Files (x86)\AviSynth+\plugins64\AddGrainC.dll [1.7.1.0] C:\Program Files (x86)\AviSynth+\plugins64\avstp.dll [1.0.3.0] C:\Program Files (x86)\AviSynth+\plugins64\Bifrost.dll [2015-05-13] C:\Program Files (x86)\AviSynth+\plugins64\colormatrix.dll [2.5.0.0] C:\Program Files (x86)\AviSynth+\plugins64\DGDecode.dll [1.5.8.0] C:\Program Files (x86)\AviSynth+\plugins64\dither.dll [2015-12-30] C:\Program Files (x86)\AviSynth+\plugins64\gradfun2db.dll [2010-03-29] [C++ 2.6 Plugins (64 Bit)] C:\Program Files (x86)\AviSynth+\plugins64+\ConvertStacked.dll [2020-06-19] C:\Program Files (x86)\AviSynth+\plugins64+\DirectShowSource.dll [2020-06-19] C:\Program Files (x86)\AviSynth+\plugins64+\ffms2.dll [2020-08-22] C:\Program Files (x86)\AviSynth+\plugins64+\ImageSeq.dll [2020-06-19] C:\Program Files (x86)\AviSynth+\plugins64+\Shibatch.dll [2020-06-19] C:\Program Files (x86)\AviSynth+\plugins64+\TimeStretch.dll [2020-06-19] C:\Program Files (x86)\AviSynth+\plugins64+\VDubFilter.dll [2020-06-19] C:\Program Files (x86)\AviSynth+\plugins64\DePan.dll [2.13.1.4] C:\Program Files (x86)\AviSynth+\plugins64\DePanEstimate.dll [2.10.0.3] C:\Program Files (x86)\AviSynth+\plugins64\EEDI2.dll [0.9.2.0] C:\Program Files (x86)\AviSynth+\plugins64\eedi3.dll [0.9.2.3] C:\Program Files (x86)\AviSynth+\plugins64\ffms2.dll [2020-08-22] C:\Program Files (x86)\AviSynth+\plugins64\flash3kyuu_deband.dll [2018-05-02] C:\Program Files (x86)\AviSynth+\plugins64\FrameSel_x64.dll [2.20.0.0] C:\Program Files (x86)\AviSynth+\plugins64\LSMASHSource.dll [2020-07-27] C:\Program Files (x86)\AviSynth+\plugins64\masktools2.dll [2.2.24.0] C:\Program Files (x86)\AviSynth+\plugins64\mvtools2.dll [2.7.41.0] C:\Program Files (x86)\AviSynth+\plugins64\nnedi3.dll [0.9.4.53] C:\Program Files (x86)\AviSynth+\plugins64\RgTools.dll [0.98.0.0] C:\Program Files (x86)\AviSynth+\plugins64\SangNom2.dll [0.5.0.0] C:\Program Files (x86)\AviSynth+\plugins64\TCannyMod.dll [1.3.2.0] C:\Program Files (x86)\AviSynth+\plugins64\TComb.dll [2.0.0.1] C:\Program Files (x86)\AviSynth+\plugins64\TEMmod.dll [2020-05-10] C:\Program Files (x86)\AviSynth+\plugins64\TIVTC.dll [1.0.14.0] C:\Program Files (x86)\AviSynth+\plugins64\vinverse.dll [2013-11-30] C:\Program Files (x86)\AviSynth+\plugins64\VSFilter.dll [3.2.0.802] [Scripts (AVSI)] C:\Program Files (x86)\AviSynth+\plugins64+\colors_rgb.avsi [2020-05-20] C:\Program Files (x86)\AviSynth+\plugins64\Daa3.avsi [2019-10-06] C:\Program Files (x86)\AviSynth+\plugins64\daa3mod.avsi [2019-10-06] C:\Program Files (x86)\AviSynth+\plugins64\dither.avsi [2015-12-30] C:\Program Files (x86)\AviSynth+\plugins64\edi_rpow2_v1.0.avsi [2020-06-14] C:\Program Files (x86)\AviSynth+\plugins64\ffavisynth.avsi [2013-04-16] C:\Program Files (x86)\AviSynth+\plugins64\FFMS2.avsi [2015-05-22] C:\Program Files (x86)\AviSynth+\plugins64\GradFun2DBmod.v1.5.avsi [2019-08-04] C:\Program Files (x86)\AviSynth+\plugins64\GradFunkMirror.avsi [2020-03-16] C:\Program Files (x86)\AviSynth+\plugins64\insertalogo.avsi [2009-10-16] C:\Program Files (x86)\AviSynth+\plugins64\insertalogoLayer.avsi [2008-11-19] C:\Program Files (x86)\AviSynth+\plugins64\mt_xxpand_multi.avsi [2010-09-11] C:\Program Files (x86)\AviSynth+\plugins64\nnedi3ocl.avsi [2013-12-08] C:\Program Files (x86)\AviSynth+\plugins64\QTGMC.avsi [2018-03-16] C:\Program Files (x86)\AviSynth+\plugins64\ResizeX_v1.0.1.avsi [2020-06-14] C:\Program Files (x86)\AviSynth+\plugins64\SMDegrain.avsi [2019-07-21] C:\Program Files (x86)\AviSynth+\plugins64\xaa_v1.2.1.avsi [2020-06-14] C:\Program Files (x86)\AviSynth+\plugins64\ZoomBox.avsi [2020-02-25] [Uncategorized files] C:\Program Files (x86)\AviSynth+\plugins64+\colors_rgb.txt [2020-05-20] C:\Program Files (x86)\AviSynth+\plugins64+\ffms2.lib [2020-08-22] C:\Program Files (x86)\AviSynth+\plugins64+\ffmsindex.exe [2020-08-22] C:\Program Files (x86)\AviSynth+\plugins64\ffms2.lib [2020-08-22] C:\Program Files (x86)\AviSynth+\plugins64\ffmsindex.exe [2020-08-22] C:\Program Files (x86)\AviSynth+\plugins64\LSMASHSource.dll.bak [2017-02-24] [Plugin errors/warnings] ____________________________________________________________________________________________________________ "C:\Program Files (x86)\AviSynth+\plugins64\DePanEstimate.dll" requires the FFTW library for some functions. Note: 'libfftw3f-3.dll' can be downloaded here: http://www.fftw.org/install/windows.html 'libfftw3f-3.dll' should be placed in "System32" and/or "SysWoW64" ____________________________________________________________________________________________________________ "C:\Program Files (x86)\AviSynth+\plugins64\mvtools2.dll" requires the FFTW library for some functions. Note: 'libfftw3f-3.dll' can be downloaded here: http://www.fftw.org/install/windows.html 'libfftw3f-3.dll' should be placed in "System32" and/or "SysWoW64" ____________________________________________________________________________________________________________
				Results 1 to 18 of 18
	The Avisynth plus has both 64 and 32 bit pipelines, depending on the bitness of the host app. If you open the script in 64 bit Virtualdub, for example, it will look in the avisynth 64 bit plugins folder, and in there should be 64 bit versions of the various plugins
	I did not quite understand what you said, I use simple x264 launcher and virtualdub 64. and it fails me both
 help pls? thanks
	It is placed in the 64 bit folder, it is indeed the 64 version, but I can't work
	The host app and the plugin (in the correct Avisynth plugin folder) must both be 64 bit.
 I just tried a simple script and it works fine
 ]Code:Audio = FFAudioSource("S:\misc film\shorts\testfile.avi", track=-1) Video = FFVideoSource("S:\misc film\shorts\testfile.avi", track=-1, fpsnum=25, fpsden=1, colorspace="YV12", seekmode=0) audiodub(video,audio) ConvertToYV12()
	Removing the other filters and leaving only the essential ones, I get this error: import avi filter error. what's the point of this if I'm opening a mkv with ffvideosource ...
	There was a C language plugin variant, loaded with LoadCplugin in the script,
 this should be identified by right clicking the file ffms2.dll and checking properties.
 Try this version. Create a folder on the desktop and copy the two files in.
 Load it like this in the start of the script
 Code:Loadplugin("c:\users\user\desktop\newfolder\ffms2.dll")
	Are you sure you're using the 64 version of Virtualdub?
 Uninstall and reinstall Avisynth plus
	very sure, here you have the proof, and with the simple x264 also so you can see that the same thing happens
 I reinstalled it previously to see if it was that and the same thing happened to me
	Have you tried simple directshowsource to see if that works?
 Code:directshowsource("c:\path\file.mkv")
	In the end I have succeeded, I don't know if there was a program or something screwing around but I managed to open it at the end.
 But now the question is that it gives me a very strange error, the error is this:
 script:
 Code:LoadPlugin("C:\Users\Bau2\Desktop\ffms2.dll") ffvideosource("E:\nds\1.mkv", fpsnum=30000, fpsden=1001) trim(363, 0) QTGMC(Preset = "slower", InputType=0, SourceMatch=3, Sharpness=0.2, TR2=2, EdiThreads=8) MAA2(mask=1, chroma=false, ss=2.0, aa=48, aac=40, threads=4, show=0) LSFmod(defaults="slow",strength = 100, Smode=5, Smethod=3, kernel=11, preblur="OFF", secure=true, Szrp= 16, Spwr= 4, SdmpLo= 4, SdmpHi= 48, Lmode=4, overshoot=1, undershoot=1, Overshoot2=1, Undershoot2=1, soft=-2, soothe=true, keep=20, edgemode=0, edgemaskHQ=true, ss_x= 1.50, ss_y=1.50 , dest_x=640, dest_y=480, show=false, screenW=1280, screenH=1024) GradFun2DBmod(thr=1.6, str=1, mask=true, mode=3)Last edited by nicknamehere; 2nd Sep 2020 at 17:32.
	it seems that the error is between these two:
 QTGMC (Preset = "slower", InputType = 0, SourceMatch = 3, Sharpness = 0.2, TR2 = 2, EdiThreads = 8)
 MAA2 (mask = 1, chroma = false, ss = 2.0, aa = 48, aac = 40, threads = 4, show = 0)
 The errors are all from the qtgmc, but then the maa2 also says that there is no function named maa2, I have noticed that the fturn is not there, but the dll does not exist in 64 bits? about the qtgmc that can be?
  FFVideoSource vs LWLibavVideoSourceBy midts in forum Video ConversionReplies: 37Last Post: 6th Oct 2022, 06:14
  There is no function named FFVideoSourceBy MrTibs in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2020, 15:19
  avisynth open failure:FFVideoSource: Video codec not found using vafeBy NightBreaker in forum Video ConversionReplies: 1Last Post: 7th May 2018, 09:26
  AviSynth:can't get ffvideosource to work.By sambat in forum EditingReplies: 5Last Post: 11th Nov 2015, 09:15
  [avisynth] how to use only FFAudioSource without FFVideoSourceBy marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2015, 16:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
