When i start up vcdeasy error pops up saying no cdrw drive found/aspi problems.I have a 24x tdk,if that helps.
I updated my aspi drivers,rebooted and still no luck.
Any1 know a fix to this...?
Thanks,
Sleazy`
Results 1 to 19 of 19
Which ASPI are you using ? if it's 4.7 that would explain your problems, get only ASPI v4.6 Build 1021, and then go to the Settings in VCDEasy and enable CDRDao.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Best Regards,
Sefy Levy,
I have a sony 8X CDRW drive and it's not being recognized either...I downloaded the ASPI v4.6 Build 1021 drivers and am running Windows XP.
I'm also using VCDeasy v. 1.9
Is there something I am doing wrong? -
aceattorney, does VCDEasy tell you anything about the ASPI ?
Best Regards,
Sefy Levy,
No GNU VCDImager
No CRDAO
No Mjpeg Tools
ASPI seems valid: No
(I noticed that ASPI said yes with the newer ASPI drivers) -
Sounds like you got VCDEasy without any of the internal components, so you need to basicly download the complete VCDEasy package, or go to the settings in VCDEasy and make sure each program leads to the correct path.
As for the ASPI Driver, i'd recommand you re-install it, I know the v4.6 work on all OS's as i've tried it myself, the 4.7 causes problems, even if will be detected, you'll end up losing alot of media due to bad recordings.Email me for faster replies!
Best Regards,
Sefy Levy,
Right on, I downloaded the full package, and it allowed me to select my burner...but aspi still says no...I suppose I will try it anyway.
Hmm.. I don't recommand it.
have you tried installing the ASPI Again ?Email me for faster replies!
Best Regards,
Sefy Levy,
OK, it totally worked with the older ASPI drivers, and the full install of VCDEasy...thanks!
Glad to hear that
Good Luck with your next projects!Email me for faster replies!
Best Regards,
Sefy Levy,
Are the v4.6 Build 1021 drivers available at another location? I tried the link listed above but got a 404 error...
Thanks, -
Did you try here: http://www.whdl16709.pwp.blueyonder.co.uk/download.html ?
Best Regards,
Sefy Levy,
Yep. I tried it, too. 404 error. I'd also like a link if someone has one.
Weird, try going here: http://www.clonead.co.uk/
and then go to the Latest Download section, see if that works.Email me for faster replies!
Best Regards,
Sefy Levy,
Thanks! I was able to get the 4.60 drivers at that link. If this works, you'll be my new personal hero. :)
-bick -
No need to be a hero, i'll be happy enough to hear it worked
Best Regards,
Sefy Levy,
AVI on CDRW stops playing in DVD player?
By leonk in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2012, 21:53 -
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 10:55 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
