Use faster settings. The the x264 veryfast preset.
What CPU do you have? Your profile lists i7-750 but there is no such CPU. Maybe it's an i5-750? i7-7500U? If your CPU has Intel QuickSync you can use that for faster h.264 encoding. In Handbrake it appears as the "H.264 (Intel QSV)" codec. -
Thanks for the reply. I'm currently using an old PC with an AMD E2-1800 processor, that's probably the reason it's taking so long.
I'll try the faster preset you mention though.
Vidcoder HEVC convert has reddish picture output. Pleaase advice
By june8 in forum Video ConversionReplies: 8Last Post: 3rd Jun 2020, 13:48 -
Convert HEVC to H264 Blu Ray
By luciofulci in forum Video ConversionReplies: 3Last Post: 31st May 2019, 12:14 -
How to convert 12bit HEVC video file to 10-bit?
By batemanj in forum Video ConversionReplies: 4Last Post: 2nd Oct 2018, 13:34 -
Convert to HEVC .h265 to preserve quality and reduce file size.
By GiovannyLira in forum MacReplies: 8Last Post: 13th Dec 2017, 12:43 -
[hevc] Unknown HEVC profile: 0
By Randombit in forum Software PlayingReplies: 8Last Post: 25th Jul 2017, 12:26
