Hi,
I am a very new beginner and this is my problem.
I accidentally deleted some videos off of my sd card. These videos were shot using my Android phone. So I put my memory card in to my laptop and used several recovery softwares, ie, Stellar, Ibeesoft, and so on. I have even paid for these programs. They will bring them back and save them, but I can't play them. I get error message like with Windows Media Player "encountered a problem while playing this video", VLC just spins. I have tried online software, they will say there is no media but if i use Mediainfo, all the info is there. Also in looking at the properties of the file, I see the data (1.GB for example), etc. What do I do? Is there something there to recover or not? Thanks
Try photorec
https://www.cgsecurity.org/wiki/PhotoRec
Hopefully you have not saved anything to the SD card since the files were lost -
I have had luck opening damaged files with apps like MKVToolnix, XMediaRecode etc that will try to separate the tracks and remux or re-encode them - good luck.
I have tried what you guys have told me and this is what I got. I have an mp4 that is 7 minutes long. The video plays but no picture no sound. Any suggestion? And btw thank you for your advice.
Look at the file in a hex editor to see if it has a bunch of zeroes.
You can also post it to the forum if it's not too big, somebody will take a look -
I am so upset, Davexnet, of course it says 0s. And I know now there is nothing there to get back. In the properties it says Size, 20.7 MB (21,805,719 bytes), Size on disk, 20.7 MB (21,807,104 bytes). so I just knew it was there. I guess it is lost. Now looking in the properties of course it says where I saved it, is there anyway to find out when it was made? Can I get that much out of it.
Also, thank you for all your help. -
Lizy Smith are you for real ?
No, its not going to be helpful for the OP, his video is gone.
MP4 repair (AAC audio repair)
By holger123 in forum Newbie / General discussionsReplies: 16Last Post: 5th Jun 2020, 17:47 -
Video Repair
By niteghost in forum Newbie / General discussionsReplies: 0Last Post: 16th Apr 2020, 16:36 -
How to repair a MKV?
By pxstein in forum Newbie / General discussionsReplies: 4Last Post: 18th Mar 2020, 10:30 -
Panasonic AG-1980P repair
By snowpeck in forum RestorationReplies: 2Last Post: 18th May 2016, 07:54 -
Repair a WMA
By milo145 in forum AudioReplies: 9Last Post: 14th Dec 2015, 15:41
