I know someone who recently bought a flat screen TV from Walmart. I tried to connect a basic DVD player to the TV, but there are no RCA connections on the TV, only HDMI and RF in. How can one connect the DVD player to the TV? I don't think one of those RF converters (that convert the DVD signal to channel 3) will work because, I would have to rescan the channels on the TV to pick up channel 3, and then all the other broadcast channels would be lost. So I would have to rescan the channels on the TV each time I want to use the DVD player, and rescan again when I want to watch any broadcast TV. This is too time consuming and hassle.
You should be able to manually add channel 3 if you need to.
Unless you have a high end DVD player or already own the RF converter it is probably cheaper to buy a new DVD player with HDMI output. -
Any number of convertors RCA to HDMI an example https://www.amazon.com.au/GANA-Composite-Converter-Adapter-Supporting/dp/B0769GMV9Y
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Are you sure it doesn't have a 3.5mm socket for a combo audio RCA audio/video adapter? Many TVs I've seen don't have RCA sockets per se but do have the facility to input RCA video and Audio via a 3.5mm plug like this:only HDMI and RF in
https://www.cablechick.com.au/cables/1m-avencore-crystal-series-4-pole-trrs-35mm-to-3r...-av-cable.html
Don't do it. I have one like that and it's junk. Total WOFTAM.Any number of convertors RCA to HDMI
+1 to this.it is probably cheaper to buy a new DVD player with HDMI output. -
OK, thank you for that. TV does have 3.5mm socket and I already had the required cable. DVD player now connects no problem to the TV.Are you sure it doesn't have a 3.5mm socket for a combo audio RCA audio/video adapter?
Connect Hard Drives to TV
By kshavo in forum Media Center PC / MediaCentersReplies: 6Last Post: 28th Apr 2019, 23:45 -
How to connect a Portable DVD player to a TV using S-Video?
By ApolloVI in forum DVD & Blu-ray PlayersReplies: 10Last Post: 11th Aug 2018, 16:51 -
How to connect an iPhone to a projector?
By pixelPIC in forum User guidesReplies: 1Last Post: 11th Sep 2017, 21:09 -
Player/Hardware to connect speakers
By socrates in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jul 2017, 22:08 -
Internet won't connect, but Wi-fi does?
By aelfheah in forum ComputerReplies: 13Last Post: 23rd Nov 2015, 08:50
