I have just downloaded the latest MKVToolNix version, and as it happened with others it doesn't include GUI versions for mmg and MKVExtract, which are the ones I use most.
Is there a way to convert the included MKVmerge and MKVExtract into GUI?
If not I will have to go into all MKVToolnix versions I can find and just download those with GUI.
Are those specifically listed somewhere?
Results 1 to 10 of 10
The reason for looking for other versions is because something weird is happening with the MKVextract version inside MKVToolNix 6.8.0.
It doesn't allow me to change the destination directory of the files I extract. That never happened before. Any reason why that might be happening? -
current MKVToolNix is v49.0.0, it's an official GUI for mkvmerge ?
https://mkvtoolnix.download/links.html
gMKVExtractGUI is the current recommended GUI for demuxing. -
Mkvtoolnix-gui.exe is the current official GUI for mkvmerge (it's included in the mkvtoolnix release, at least on windows).
I see. It seems I might need a tutorial to set the best values.
There's a "Compression" item there that I'not sure what value to use with it. -
Thanks. I will start using it and see how it goes.
What does it do better, besides changing the operation procedures?
please delete. thanks
By mrjayviper in forum Video ConversionReplies: 0Last Post: 11th Feb 2018, 04:24 -
MKVMerge GUI not in my MKVToolnix
By gumbygum in forum EditingReplies: 4Last Post: 23rd Mar 2017, 00:44 -
MKVToolNix GUI not importing subtitles from MP4...
By syrist in forum Video ConversionReplies: 5Last Post: 23rd Jan 2017, 09:34 -
AR (aspect ratio) 2.21:1 in tsMuxer 2.6.12 and in MKVToolNix GUI 9.2.0 ??
By anhlinhp4 in forum Authoring (Blu-ray)Replies: 4Last Post: 16th Dec 2016, 05:36 -
MKVToolNix GUI v8.9.0 issue with timecodes
By Han Solo1 in forum Newbie / General discussionsReplies: 6Last Post: 13th Mar 2016, 18:55
