i can't find any information on how how to download from itv.com
Results 1 to 25 of 25
You can use youtube-dl with the videolink example https://www.itv.com/hub/liar/2a4547a0007 goodluck
Bottom line.
If you get a message and can not actually view the video then you need a proxy.
Now I am rather surprised. In the past I have generally failed to download form the ITV Hub. The ads before the program would download but not the program. In fact this is still the case with my main downloader/stream-recorder of choice. That failed due to the manifest which is fragmented - it grabbed the fragments but were useless.
However using youtube-dl, or rather in my case TVDownloader which is a front-end for the cmd line program so avoids all the complexities of parameters, I have just downloaded a program which I did not even know was on there and was about to be removed. In all a happy bunny. -
use latest youtube-dl and if your outside the uk use a vpn or a proxy also download everything you want now before they protect everything with DRM i suggest tvdownloader makes things more easy goodluck
I have the same issue as the OP except that my video plays in the browser (Chrome)
I am using the latest youtube-dl package also. I even tried the TVDownloader frontend but got the same error.
The link is: https://www.itv.com/hub/manhunt/2a5386a0004
Error:Code:[ITV] 2a5386a0004: Downloading webpage [ITV] 2a5386a0004: Downloading JSON metadata ERROR: Unable to download JSON metadata: HTTP Error 404: Not Found (caused by HTTPError()); please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
Even with a user and password specified, the same error is produced.
Could you please see if you can download from https://www.itv.com/hub/manhunt/2a5386a0004Code:youtube-dl.exe -u xxxxxxxx -p yyyyyy https://www.itv.com/hub/manhunt/2a5386a0004
if u want us to help you write here your username and passw, or burn new fake user/passw only for this purpose.
Do a few/several refreshes on the site until you get a mpd that's like this
and use that mpd with ytdlp.Code:.mpd?hdnea...
Usually you get a mpd like this
and this mpd is better protected, you can't download from that. Or I can't find a way.Code:.mpd?Policy...
Actually there's a way, use Stream Detector add on, it gives you a proper ytdlp instruction with the necessary parameters. -
Once I found a video with parameters like that at the end of the link (it also had others called Signature and Key-Pair-Id). To download it I just had to add them as request headers using --add-header "Policy:value", etc.
It was an m3u8 link, but I guess it also should work with mpd links if they are not encrypted. -
When not using Stream Detector, few F5 refreshes will eventually get you the "easy" mpd which can be viewed using developer tools -> network tab.
Stream Detector, no matter the refreshes should give you a code that will download regardless of the type of mpd you get.
You are replying after 20 days... -
Thank you and sorry for the late reply.
Stream Detector gave me this link for TV series 'Hollington Drive'.
I tried the latest version of YT-DLP and got the error belowCode:https://itvpnpdotcom.cdn1.content.itv.com/10-0552-0002-001/18/1/VAR028/10-0552-0002-001_18_1_VAR028.ism/.mpd?Policy=eyJTdGF0ZW1lbnQiOlt7IlJlc291cmNlIjoiaHR0cHM6Ly9pdHZwbnBkb3Rjb20uY2RuMS5jb250ZW50Lml0di5jb20vMTAtMDU1Mi0wMDAyLTAwMS8xOC8xL1ZBUjAyOC8xMC0wNTUyLTAwMDItMDAxXzE4XzFfVkFSMDI4LmlzbS8qIiwiQ29uZGl0aW9uIjp7IkRhdGVMZXNzVGhhbiI6eyJBV1M6RXBvY2hUaW1lIjoxNjM0MTgxMDQ1fX19XX0_&Signature=Sfoh5cTheV1zjRMdGdJfiOt0BN6g7hlUvrzXaKP~OPo1zqUFAO4rNhKTZOUy4Esw421ikm2Mbe69Dn1YgftqqpVUGo7m7eghz3bI1FINvlwtcyLiA-Msn8kcX-NjvW5RFl59y8tISGE~orn7XRNP9vuB1eM8wmRESHKShYEAnRrxjfVhwQ8CqrPLWHmycgJ8xn5376Yfon0BrtnqdwZ7CPVsgiqwjoluMx5SWy3K-SyBjMnHoXlJh-z73fr2XtmXa-zc8fIxlYd81KXjZz9aIwDmMEBGJ00vXKWI4HSbTb4thHOCTTYFffQBJT9b4I1W8p8GJrHLtXh1dKEzLUHVng__&Key-Pair-Id=APKAJB7PCFZAZHWZVIBA
Code:yt-dlp.exe https://itvpnpdotcom.content.itv.com/10-0552-0002-001/18/1/VAR028/10-0552-0002-001_18_1_VAR028.ism/.mpd?hdnea=st=1634158585~exp=1634180185~acl=/10-0552-0002-001/*~data=nohubplus~hmac=1714c7d62f7a26b204119980d0cd706d6af4609b6b8e99bd5 b00b8c6182de38f [generic] *~data=nohubplus~hmac=1714c7d62f7a26b204119980d0cd706d6af4609b6b8e99bd5b00b8c6182de38f: Requesting header WARNING: [generic] Falling back on generic information extractor. [generic] *~data=nohubplus~hmac=1714c7d62f7a26b204119980d0cd706d6af4609b6b8e99bd5b00b8c6182de38f: Downloading webpage [generic] *~data=nohubplus~hmac=1714c7d62f7a26b204119980d0cd706d6af4609b6b8e99bd5b00b8c6182de38f: Extracting information ERROR: [generic] *~data=nohubplus~hmac=1714c7d62f7a26b204119980d0cd706d6af4609b6b8e99bd5b00b8c6182de38f: This video is DRM protected
After using --allow-u i got an MP4 and an M4A file. Is any further processing required to make the MP4 file playable?
Itv subtitles
By codymts in forum SubtitleReplies: 1Last Post: 11th Dec 2020, 16:30 -
help to download videos from shahid
By hotboy87 in forum Video Streaming DownloadingReplies: 17Last Post: 14th Feb 2020, 12:53 -
download videos
By jhone in forum Video Streaming DownloadingReplies: 1Last Post: 27th Oct 2017, 17:07 -
How to download DT videos?
By YihuYon in forum Video Streaming DownloadingReplies: 0Last Post: 8th Apr 2016, 07:43 -
I'm trying to download these videos:
By thegeet in forum Video Streaming DownloadingReplies: 2Last Post: 17th Dec 2015, 23:07
