Results 1 to 20 of 20
  1. Hi,
    I've downloaded a full TS file from a streaming site (Beamafilm) but when I play it back in VLC player there's only audio and no video.
    The output from MediaInfo is:
    General
    Complete name : Film.ts
    Format : MPEG-TS
    File size : 249 MiB
    Duration : 3 s 520 ms
    Overall bit rate : 724 Mb/s
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4
    Format settings : CABAC / 5 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 5 frames
    Codec ID : 27
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Menu ID : 1 (0x1)
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Format version : Version 4
    Muxing mode : ADTS
    Codec ID : 15-2
    Bit rate mode : Variable
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Menu
    Menu ID : 1 (0x1)
    List : 256 (0x100) (AVC) / 257 (0x101) (AAC)
    Service name : HLS
    Service provider : Vimeo
    Service type : digital television
    Is there anything I can do to make the video work?
    Thanks,
    Becca
  2. Does the duration seem correct ? Duration : 3 s 520 ms.
    File size : 249 MiB
    some suggestions:
    try a different player (ex: mpc-hc)
    try remuxing to mp4:
    ffmpeg -i "input.ts" -c copy "output.mp4"
    if needed see: https://forum.videohelp.com/threads/398507-Top10-Commands-for-Lossless-Video-manipulat...eg-%28Guide%29
    try opening in an editor such as avidemux.
  3. Originally Posted by butterw View Post
    File size : 249 MiB
    some suggestions:
    Hi, thanks for your help. Tried all of what you suggested without any luck
    Mar 2008
    Open MKVtoolnix GUI and add your .ts file
    Hit the "Start multiplexing" button and create an MKV.
    Does that work?
  5. Originally Posted by davexnet View Post
    Does that work?
    Hi, I added the file to MKVtoolnix and it multiplexes/exports as a .mka file by default or .mkv if overwritten. Either file is very small (16MB) and only contains audio. MKVtoolnix says the "Container" is "MPEG transport system".
    Thanks, Becca
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Something wrong as it says it's 3 s 520 ms Does it play for longer in any media player?
  7. Originally Posted by netmask56 View Post
    Hi, yes, it plays the audio for the entire duration of 8m 48s.
    Thanks, Becca
  8. Another Try. Load your file in Tsmuxer. Is the video stream displayed and in what length? Remux to a new ts file.
  9. Member Emeritus
    May 2014
    Originally Posted by rebeccas View Post
    I've downloaded a full TS file ...
    How did you download it? Did you start with the master.m3u8 url, or not?
    ... from a streaming site (Beamafilm) ...
    It appears that Beamafilm sends video via vimeo. If they use the vhx flavor of vimeo (rather than standard vimeo), there may be drm involved.
  10. Originally Posted by ProWo View Post
    Hi,
    In Tsmuxer it says: ""Some tracks not recognized. This tracks was ignored." Only the audio (AAC) loads.
    Thanks, Becca
  11. Originally Posted by ponens View Post
    >>> No, only the TS file is available.
    >>> The download link begins with: https://166vod-adaptive.akamaized.net
    Thanks, Becca
  12. Member Emeritus
    May 2014
    If you didn't start with the hls playlist (or master.m3u8), what you've downloaded is likely not complete. It's unlikely that what you've downloaded contains playable video, and you'll need to start over using the playlist.
    That very small piece of information doesn't help very much. What does it end with?
    Again, how did you download it? Did you use a program, or just click the "download link" or ???
    This shouldn't be like pulling teeth. Answer thoroughly so that the same questions don't need to be repeated.
    See here and here.
  13. Originally Posted by ponens View Post
    >>> I said above that it was a TS file.
    >>> Program: Internet Download Manager
    See here and here.
    See my answers above inline.
  14. Member Emeritus
    May 2014
    IDM produced a .ts file, or the source url ends in ".ts"?
    IDM used a master.m3u8 & playlist.m3u8 url to produce a .ts output file. This can be checked by right-clicking on the file in IDM, choosing properties, and examining the full address.
    Checking the following trailer on beamafilm;
    https://beamafilm.com/watch/cobby-the-other-side-of-cute
    The first url called for the video is;
    https://player.vimeo.com/external/444403640.m3u8?s=<code>
    Which redirects to a master.m3u8 url, and then to a playlist.m3u8 url.
    The playlist.m3u8 contains seperate audio and video tracks.
    Perhaps IDM did not combine the separate audio and video tracks correctly.
    Suggest you start over using streamlink. Or, you can keep trying to fix what you've already downloaded with IDM.
  15. Originally Posted by ponens View Post
    Hi,
    Thanks for the explanation.
    IDM did use a m3u8 file as you said. Is this an issue with IDM (because beamafilm used to work without any issues) or have beamafilm changed the way they deliver?
    I had a look at streamlink. If using streamlink is there any option to download the movie immediately or must it be streamed and recorded through a player like VLC?
    Thanks, Bec
  16. This is going in circles.
    Did you find the url '.m3u8' or not?
  17. Originally Posted by LZAA View Post
    Hi, thanks for your patience.
    The URL is https://79vod-adaptive.akamaized.net/exp=1598532280~acl=%2F71091dd8-a963-4f90-b503-d32.../playlist.m3u8
    Bec
  18. Hello, thank you; however, there is no audio. Are you able to download the TS with combined video and audio? Also, how did you download this? Tanks
  19. Read carefully the messages of mister ponens.
