How do I create and name chapters in a 3 hour h264/mp4 file? Would also be good if these chapters are also marked after uploading it to youtube.
Thanks!
Ok, I will look forward it!
clicks per second test to check yours onlineLast edited by RickySmith; 24th Aug 2020 at 23:47.
AFAIK, you can only create bookmarks in Potplayer. Those bookmarks won't do you any good in YouTube though.
If your computer has a graphics card, you can use DaVinci Resolve* to create chapters, label those chapters, and have them work in both Potplayer and YouTube. Set markers in the timeline as you're editing you video. Once you're happy with the everything, go to "Deliver", and tick the box that says "Chapters from Markers".
* https://www.blackmagicdesign.com/products/davinciresolve — the regular version is free -
can davinci do smart recode (i.e. stream copy) without long rendering times if all I'm doing is trimming + adding chapters?
use losslesscut to import potplayer bookmarks. it will generate chapters
Hey, do you know how to make chapter titles in Potplayer visible? Similar to VLC where you hover during a video chapter/section and it displays the name of the chapter. Potplayer only shows the separation marks for the chapters, but not their names.
Creating Chapters with BDMV file, using Handbrake
By safarian24 in forum Newbie / General discussionsReplies: 0Last Post: 9th Mar 2019, 14:45 -
First 2 seconds lag when playing on PotPlayer x64
By savvyguy in forum Newbie / General discussionsReplies: 0Last Post: 25th Dec 2018, 19:47 -
Total disable file history in PotPlayer x64
By savvyguy in forum Software PlayingReplies: 1Last Post: 24th Dec 2018, 13:47 -
How do I stop PotPlayer from automatically creating a playlist?
By Kizzume in forum Software PlayingReplies: 2Last Post: 8th Oct 2018, 22:05 -
PotPlayer x64 crashes on Windows 10 Creators Update?
By Wilda in forum Software PlayingReplies: 5Last Post: 20th Jul 2017, 08:18
