Hi there! Is there any practical difference between the LHI and LHE in the context of capturing analog video? I am being asked to capture a couple hundred VHS and Hi8 tapes and want to make sure I end up with the right card. The signal flow will be AG-1980 > EVAL-ADV7842 > Kona. Thanks!
Lhe can't do hdmi, right? Or am I missing something?
Edit: the reason I bring this up is because the EVAL-ADV7842 is hdmi out only.Last edited by ugnaught; 13th Sep 2020 at 22:29.
There are some Aja Kona cards that can capture S-Video, I don't see why would you go to the trouble of capturing HDMI which may end up disastrous considering the amount of tapes you have, You can't just recapture 200 tapes if something goes wrong later on.
aja kona lhi capture software
By hdfills in forum Capturing and VCRReplies: 5Last Post: 30th Dec 2020, 05:58 -
which capture card is best for vhs and hi8 capture
By hdfills in forum Capturing and VCRReplies: 13Last Post: 23rd Jun 2020, 17:59 -
ATI all in wonder 9800 pro and sata. VHS lossless capture.
By AmigaFanBoy in forum Capturing and VCRReplies: 7Last Post: 13th Nov 2019, 22:36 -
best capture card for vhs and hi8 capture
By hdfills in forum Capturing and VCRReplies: 4Last Post: 18th Oct 2018, 12:21 -
DV conversion vs lossless capture - comparison (Hi8) [WARNING: auto-load!]
By Brad in forum Capturing and VCRReplies: 25Last Post: 14th Feb 2016, 15:36
