Results 1 to 10 of 10
  1. import os
    import vapoursynth as vs
    import havsfunc as haf
    import G41Fun as fun
    import mvsfunc as mvs
    import descale as descale
    import kagefunc as kage
    core = vs.get_core()
    #core.max_cache_size = 1000 #Use this command to limit the RAM usage. 1000 or 2000 is fine.
    script_dir = os.path.dirname(__file__)
    rel_path = "video_cut/cut.mkv"
    abs_file_path=os.path.join(script_dir, rel_path)
    video = core.lsmas.LWLibavSource(source=abs_file_path)
    #Trim returns a clip with only the frames between the arguments first and last, or a clip of length frames, starting at first. a = first frame, b = last frame
    #video = core.std.Trim(video, a, b)
    #Resizer content goes here
    video = haf.QTGMC(video, Preset="Slower", TFF=True, FPSDivisor=2)
    video = core.fmtc.resample(video, css="444")
    video = descale.Debilinear(video, 914,514)
    video = mvs.BM3D(video, sigma=3.72, radius1=1, profile="fast", matrix="709")
    video = core.knlm.KNLMeansCL(video, 0, 6, 4, 6.76, channels="YUV")
    video = fun.FineSharp(video, sstr=1.97)
    video = core.std.CropRel(video, left=289, top=106, right=357, bottom=58)
    video = core.fmtc.bitdepth(video, bits=16)
    video.set_output()
    and then this shows
    Failed to evaluate the script:
    Python exception: No attribute with the name lsmas exists. Did you mistype a plugin namespace?
    File "src/cython/vapoursynth.pyx", line 2244, in vapoursynth.vpy_evaluateScript
    File "src/cython/vapoursynth.pyx", line 2245, in vapoursynth.vpy_evaluateScript
    File "/Library/Frameworks/VapourSynth.framework/video_edit/script.vpy", line 17, in
    File "src/cython/vapoursynth.pyx", line 1756, in vapoursynth.Core.__getattr__
    AttributeError: No attribute with the name lsmas exists. Did you mistype a plugin namespace?
    does anyone know why this is showing up?
  2. My guess is you are missing the LSMASH-Works plugin or one of its dependencies.
    https://github.com/HolyWu/L-SMASH-Works/releases/
  3. Originally Posted by sneaker View Post
    ive downloaded the plugin and dependencies many times and this error just shows up... ive completely deleted and reinstalled vapoursynth many times and this error shows up even when the plugin is in the folder. I might be doing it wrong since i havent found anywhere explaining how to download dependencies.. but ive downloaded the plugin many times and put it in every folder i can think of and nothing works :(
  4. May be https://github.com/Selur/hybrid-vapoursynth-addon helps a bit, these are the scripts I use to build Vapoursynth and the a bunch of plugins Hybrid uses.
  5. video = core.lsmash.LWLibavSource(source=abs_file_path)
    Missing h maybe
    Big hint
  6. lsmas (without the h) is the correct namespace for the plugin
    Are you on a Mac ?
    Did you install using brew ; and did you setup UserPluginDir and SystemPluginDir
    https://forum.doom9.org/showthread.php?t=175522
    Did you try loading plugin manually with core.std.LoadPlugin ?
  7. Originally Posted by poisondeathray View Post
    Are you on a Mac ?
    im on mac. i installed with brew, put the plugin in the folder, and did the terminal lsmash setup.‬ i dont know if i set those up but i followed every step on that site when downloading plugins so i think i did.. ill try again though and how do i load a plugin with that?
    i dont know much about vapoursynth sorry and most things i look up are for windows :/
  8. To load that plugin manually:
    core.std.LoadPlugin('...path to your plugin...\vslsmashsource.dylib')
    note: I'm guessing name "vslsmashsource.dylib" for that plugin, I do not have Mac.
    if it gets loaded and other errors show up like not knowing attribute fmtc that you use in script, then things do not work in general, vapoursynth cannot see plugin directory
  9. l33tmeatwad has precompiled plugins in his Mediafire folder.
    You can try downloading the file from https://www.mediafire.com/folder/wvdlnjapm1vvw#e08z7s08yi74i extract it and move the dylib file into your autoload folder,... (probably '/usr/local/lib/vapoursynth')
  10. Originally Posted by Selur View Post
    i did what you said and i got the fmtc error that _AI_ was talking about.. can vapoursynth not see the plugin directory, and how do i make it see the plugins? everything i look up is windows so i have no idea
    Python exception: There is no attribute or namespace named fmtc
    File "/Library/Frameworks/VapourSynth.framework/video_edit/script.vpy", line 23, in
    video = haf.QTGMC(video, Preset="Slower", TFF=True)
    File "/Library/Frameworks/VapourSynth.framework/lib/python3.8/site-packages/havsfunc.py", line 1122, in QTGMC
    bobbed = Bob(clip, 0, 0.5, TFF)
    File "/Library/Frameworks/VapourSynth.framework/lib/python3.8/site-packages/havsfunc.py", line 5024, in Bob
    clip = core.std.SeparateFields(clip, tff).fmtc.resample(scalev=2, kernel='bicubic', a1=b, a2=c, interlaced=1, interlacedd=0)
    File "src/cython/vapoursynth.pyx", line 1443, in vapoursynth.VideoNode.__getattr__
    AttributeError: There is no attribute or namespace named fmtc
