  1. Member Randombit's Avatar
    Dec 2010
    Acadiana
    I have an old OGG file, for same strange reason it identifies itself with 11.025 kHz sample rate. The correct rate would be 44.1 kHz. Is there a way to edit its properties without recoding? I admit I do not know the anatomy of OGG file, is it a container? Is there a container header which can be edited?
    Mar 2008
    Not sure about that. Have you considered a workaround ?
    Fix it in Audacity then save it to a lossless file, such as Wav or Flac
  3. Member Randombit's Avatar
    Dec 2010
    Acadiana
    mpv --speed=4 --audio-pitch-correction=no 07.ogg
    This command plays the file correctly. Methinks this 11025 value is stored in vorbis itself, not in ogg container. Anyhow, there is certainly a way to correct it, with hex editor if no proper tool is found. The only difficulty is to find the byte(s) to alter.
    Mar 2008
    Perhaps
    https://stackoverflow.com/questions/45231773/how-to-get-sample-rate-by-ogg-vorbis-byte-buffer
  5. Member Randombit's Avatar
    Dec 2010
    Acadiana
    Thanks! This looks promising indeed.
    Edit: No luck, the "fixed" file gives CRC error. I didn't expect that.
  6. Member Randombit's Avatar
    Dec 2010
    Acadiana
    My computer tells me this is a DOS executable, I do not run DOS. Thanks anyway.
