For the sake of completeness, here is your latest sample in the 360p version as encoded by yt.
I am probably wrong but I thought that 44.1 hz was the standard for online video.
Results 31 to 42 of 42
Maybe, I just though that video's audio is always 48Khz and audio only is 44.1 Khz red book.
opus audio seems to be 48KHz, m4a 44.1KHz.
Interestingly, I did one resize to 1080 and without encoding it to mp4 first youtube successfully encoded it in 1080p60, Very strange. I think from now on this is the way of uploading SD videos to youtube.
File spec before uploading to youtube:
Format : HuffYUV
Format version : Version 2
Codec ID : HFYU
Duration : 1 min 21 s
Bit rate : 420 Mb/s
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan type : Interlaced
Bits/(Pixel*Frame) : 4.504
Stream size : 3.97 GiB (100%)
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 1
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 14.9 MiB (0%)
Alignment : Aligned on interleaves
Interleave, duration : 17 ms (1.01 video frame)
Interleave, preload duration : 500 ms -
Oh okay, good to know, Though my mp4 encoded files are always 48Khz, I use this commend:
Code:ffmpeg -i In.avi -vf "format=yuv422p,setsar=sar=10/11" -c:v libx264 -crf 10 -x264opts colorprim=smpte170m:transfer=smpte170m:colormatrix=smpte170m:force-cfr -c:a aac -b:a 192k Out.mp4
360p is the default quality that a video is given first out of the gate. People who follow channels closely will often put in the comments "360p gang" meaning that they are early to a video being posted, before YT processes the video more with better options. Did it ever go above 360p?
Opus will always report 48khz I think. But it uses other means to drop the sample rate/bandwidth. I'm not really sure how it works exactly. https://hydrogenaud.io/index.php?topic=105326.0Last edited by KarMa; 24th Aug 2020 at 02:50. Reason: 360p not 320p
I waited several days still 4kdownloader reports 360p as the highest quality so it was something wrong with that upload.
I had media info reporting an interlaced video as progressive, so it is not reliable in that area.
Files can be tagged wrong.
mp4/h264 has a per-frame Interlaced tag, which can be viewed with ffmpeg/ffprobe.
Need help to compile Youtube-dl on Windows platform
By skizzino in forum Video Streaming DownloadingReplies: 0Last Post: 30th May 2019, 12:37 -
Youtube streaming is made easier
By TreeTops in forum Latest Video NewsReplies: 0Last Post: 22nd Mar 2018, 11:46 -
Recommended cross-platform way to convert mp3/audio files 4 YouTube upload?
By colorstar in forum Video ConversionReplies: 2Last Post: 12th Dec 2017, 10:45 -
Recommended command line cross-platform download tool, not youtube-dl?
By colorstar in forum Newbie / General discussionsReplies: 0Last Post: 12th Dec 2017, 07:38 -
Youtube-dl streaming errors ?
By PowerFalcon in forum Video Streaming DownloadingReplies: 2Last Post: 24th May 2016, 08:46
