What are my options if I want to take a HuffYUV captured AVI and do a lossless conversion to UTVideo codec? UTVideo plays a bit nicer when editing on OSX, so I need to convert an old capture.
Am I right in thinking that VirtualDub should handle this fine if I do a "Full Processing" and select UTVideo as my compression? Or should I let ffmpeg handle this type of thing?
Thanks!
	Use VirtualDub in Fast Recompress mode will pass the output of the huffyuv decoder to the UT video encoder.
 ffmpeg should be fine too. Personally I'd do it with ffmpeg with a batch file. Put the batch file in your SendTo folder and you can right click on a huffyuv avi file in Explorer and select Send To -> ConvertToUT.bat (or whatever you name the batch file).
  FFMPEG - hevc_nvenc & h264_nvenc lossless presets not truly lossless?By AnomalyDetected in forum Video ConversionReplies: 5Last Post: 27th Oct 2019, 03:24
  Lossless encoding without increasing sizeBy Megafox in forum Newbie / General discussionsReplies: 10Last Post: 20th Sep 2018, 17:56
  convert h.264 to lagarith/utvideo/huffyuvBy nixiejames in forum Video ConversionReplies: 16Last Post: 1st Apr 2017, 09:33
  X265 "Lossless" not really lossless and I can prove itBy sophisticles in forum Video ConversionReplies: 21Last Post: 3rd Feb 2017, 22:54
  Encoding Guide on Lossless vs FrameservingBy SameSelf in forum Video ConversionReplies: 2Last Post: 16th Feb 2016, 08:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
