I have tried numerous times with automatic synchronizers but it does not work, can anyone help me?
Link to files to be synched:
https://drive.google.com/file/d/1FNsuHlv-SN-qT-9bGKPWdUrGRntM8x-b/view?usp=sharing
https://drive.google.com/file/d/1-7tVWYJrWXOf8taOay5tJstcCFMNNyap/view?usp=sharing
See if you can make it work
Hi jooj
I would like to suggest you to use Subtitld, with the "Gap" tool:
https://www.youtube.com/watch?v=AzlAJXCwXHI
I believe you can fix this manually with the Gap tool.
Thanks for your attention. -
Just to clarify, you are focused on synchronization, i.e. adding the time codes of when text should appear. I'll assume that you already have a transcript of the video.
If so, I actually think YouTube is excellent for this. Upload your file on YouTube and mark it Private. Then follow these instructions:
https://support.google.com/youtube/answer/2734796?hl=en
To get the the transcript to split the transcript into logical chunks, I recommend doing this with your transcript file before uploading:
https://support.google.com/youtube/answer/2734799
Try it out. It works really well for me.
audio synchronization
By aeon1 in forum Newbie / General discussionsReplies: 7Last Post: 8th Aug 2020, 18:40 -
Video import -synchronization?
By bhgateley8 in forum Newbie / General discussionsReplies: 10Last Post: 14th Oct 2019, 08:24 -
Video and Audio Synchronization
By Anotia in forum Newbie / General discussionsReplies: 6Last Post: 17th Aug 2019, 15:21 -
any easy and simple software to fix video and audio out of synchronization?
By kenny1999 in forum Newbie / General discussionsReplies: 9Last Post: 4th Oct 2018, 09:18 -
Framerate and synchronization issue (29.97FPS)
By abolibibelot in forum Video ConversionReplies: 20Last Post: 28th Aug 2016, 18:32
