Hi everybody, I converted it using this guide http://www.digital-digest.com/articles/VidCoder_Tutorial_page2.html
I choose the H264 MKV 480p30 preset from the Matroska section and then I set the Sizing tab like this
and the Video encoding tab like this
And here is my question: in this tab there is the "Encoder settings" section. Do I have to change something or not? Thanks
Why are you resizing to 720x480? You only need to do that if you're making DVDs and encoding MPEG 2 -- which obviously you are not since you are encoding with x264. If your source is 16:9 you should resize to 852x480 or 720x404. If the source is 4:3 you should resize to 640x480.
I'm sorry, I didn't answer because I didn't need to convert that file anymore. But now I need to convert another one, so I can answer. I choose the 720x480 resolution so it results 720x404 in the output section.
[Attachment 55176 - Click to enlarge]
If I put 720x404, it results 718x404.
[Attachment 55177 - Click to enlarge]
Source is 16:9. I've got another question, about the Audio encoding section.
[Attachment 55178 - Click to enlarge]
In this case source is dts/ac3 5.1 channels. Is it a good idea to convert in aac (mixdown stereo)? If yes, I don't know what to choose: bitrate or quality? I tried with auto bitrate and the result is a 50 MB audio (video has a length of 43 mins). Choosing default (5) quality instead, result is 120 MB. I think 120 MB is too much, considerating that video track is 235 MB. -
Get rid of one audio track, unless you want to keep both Eng and Ita.
Downmixing to aac stereo 128kbps will give good results and will play without issues (though obviously you lose 5.1 audio). -
What's the best way to change a video (.mkv) resolution?
By MC23 in forum Newbie / General discussionsReplies: 7Last Post: 30th Apr 2020, 14:22 -
Help Upscaling 480p NTSC DVD's To Progressive 720p Video
By LouieChuckyMerry in forum Video ConversionReplies: 16Last Post: 7th Mar 2020, 14:47 -
Re-Encode HD HEVC to UHD H.264 MKV / Change Resolution
By Dabuss55 in forum Video ConversionReplies: 4Last Post: 10th Jul 2018, 04:44 -
Converting 720p to 480p (Getting rid of black bars on the side of 720p)
By fri3ndlygiant in forum Video ConversionReplies: 5Last Post: 22nd Mar 2016, 06:20 -
help upscaling anime 480p to 720p with Megui and avisynth
By zanzar in forum Newbie / General discussionsReplies: 7Last Post: 5th Feb 2016, 14:39
