There is probably an easy answer for this but it eludes me. I have a video with cabac/ 5 ref format and cutting and merging works well and maintains this format. My problem is when I try to encode a portion so I can merge it with a section that has been codec copied, now matter what I try, I get the same High@L3.1 / 4 ref format.
I am using this script:
What the encoded mediainfo information shows is:Code:ffmpeg -i "D:\Replay Media Catcher\Compilation Zeroed.mp4" -ss 26.293196 -vframes 823 -c:v libx264 -b:v 397k -r 29.97 -c:a aac -ar 44100 -ab 144k -x264-params refs=5:me=hex:subme=8:psy=1:mixed-refss=1:me-range=16:chroma-me=1:trellis=2:8x8dct=1:cqpfile=0:fast-pskip=1:chromaoffset=-2:lookahead-threads=1:sliced-threads=0:nr=0:interlaced=0:bluray-compat=0:constrained-intra=0:bframes=3:b-pyramid=2:b-adapt=1:b-bias=0:directpred=3:weightb=1:open-gop=0:weightp=2:keyint=90:min-keyint=46:scenecut=0:intra-refsresh=0:rc-lookahead=50:mbtree=1:crf=23.0:qcomp=0.60:qpmin=0:qpmax=69:qpstep=4:vbv-maxrate=2000:vbv-bufsize=66:crf-max=27.0:nal-hrd=none:filler=0 -y "D:\Replay Media Catcher\T_0_0_Compilation_Zeroed.mp4"
Video
Format : AVC
Format profile : High@L3.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : avc1
I just need to know if it is possible to duplicate the original videos format and how if it is.
Thank you!
Okay,solved my problem. It turns out using <-preset slow> will give 5 reference frames automatically and USUALLY matches the x264 parameters in the existing complete video. There are those that have been encoded, transcribed, edited, and merged from who knows what program or multiple programs at different times.
For these I found if you use the FFMpeg <-Refs x> attribute, libx264 will set the encoded segment to that amount of reference frames. The bad part about doing it this way is that if you end at a reference frame or predicted? frame, FFmpeg will cause a glitch in the output. Case in point:
End of encoded segment: with B Frames= 3
No. pts_time type
233 7.774441 0 P
234 7.807808 0 B
235 7.841175 0 B
236 7.874541 0 B
237 7.907908 0 P
238 7.941275 0 B
239 7.974641 0 P
Copied segment beginning:
0 0.000000 1 I
1 0.033367 0 B
2 0.066733 0 B
3 0.100100 0 B
4 0.133467 0 P
5 0.166834 0 B
6 0.200200 0 B
7 0.233567 0 B
8 0.266934 0 P
FFmpeg creates a merged video at the merged point:
233 7.797464 0 P
234 7.830831 0 B
235 7.864198 0 B
236 7.897564 0 B
237 7.930931 0 P
238 7.964298 0 B
239 7.997664 0 P
240 8.429012 1 I almost a half second freeze frame
241 8.462379 0 B
242 8.495746 0 B
243 8.529112 0 B
244 8.562479 0 P
I'm sure the experts here know this but in case someone else is having trouble cutting the odd video they downloaded, they will at least know why and can experiment for a fix. In this case, removing the incomplete 'B' frame group from the encoded segment ((PBP -> P) before merging fixed my joining problem.
Long story short for me... stick to Presets whenever possible but understand you may have problems cutting and joining, especially with higher Ref frames numbers. In my case Ref 1/2/3/4 were no problem merging to an encoded segment from the same video. Only Ref 5 and above caused problems with FFProbe, FFPlay and FFMpeg, hence this thread. It's now possible for me to cut accurately within, in my case shown, 2 X 0.033367, 67 thousandths of a second without a noticeable glitch.
Thanks to everyone that offered a suggestion and if anyone knows of another fix for the Joining problem I listed above, I would love that information.
ffmpeg cut point wrong with 5 reference frames video
By Budman1 in forum EditingReplies: 9Last Post: 8th Aug 2020, 12:06 -
Patch encoder to force P-Frames to only reference I-Frames
By zombiitv in forum ProgrammingReplies: 1Last Post: 9th Sep 2019, 21:51 -
libx264 is no longer available in ffmpeg?
By oduodui in forum LinuxReplies: 2Last Post: 17th Feb 2019, 13:49 -
high 10@L5.1 and 16 reference frames
By nixiejames in forum DVB / IPTVReplies: 6Last Post: 29th Jun 2016, 18:01 -
Reference frames and Bframes
By lolman in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2015, 09:14
