Is it possible to install VapourSynth on Mac OS X 10.10 Yosemite?
Ultimate goal is to use QTGMC in Hybrid.
Started reading this: https://forum.selur.net/showthread.php?tid=1279 which references not passing 10.14 but I don't know if older versions are also ok.
Searching Google keeps leading me here: https://forum.doom9.org/showthread.php?t=175522 which references 10.12 (also, scrolling down this page makes me think this might be over my head)
Have you tried compiling Vapoursynth yourself?Is it possible to install VapourSynth on Mac OS X 10.10 Yosemite?
see: http://vapoursynth.com/doc/installation.html#linux-and-os-x-compilation-instructions
Running Hybrid with Vapoursynth on Mac OS X 10.10:
I strongly doubt it's possible without:
a. running it inside a virtual machine.
or
b. me personally spend time to setup a Mac OS X 10.10, adjust current source code of Hybrid to be compatible with 10.10 and then send time to compile all the tools Hybrid uses for 10.10. So even for me this would be a project for quite a while. So you without having access to the source code have no chance in this direction.
Another problem:
Hybrid for Yosmite was never build with Vapoursynth support which was added in the second half of 2016 at which time Sierra (10.12) was used, so even if you got your hand on an old Hybrid build which would run on Mac OS X 10.10 it wouldn't support Vapoursynth.
=> only way I see this working would be to run Hybrid inside a virtual machine which at least runs with Windows 7, there current Hybrid Windows release should run fine.
Cu Selur
Ps.: bootcamp with Windows 7 would also be a way.users currently on my ignore list: deadrats, Stears555, marcorocchini -
On a Windows system all the main tools come with Hybrid (stuff like NeroAacEnc, fdkaac,..) can't be added due to license restrictions, but QTGMC should work out of the box.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2357Last Post: 1st Aug 2025, 05:32 -
Strange issue DeInterlacing DV capture - QTGMC-Bob (Hybrid Vapoursynth)
By SupermanTV in forum Capturing and VCRReplies: 23Last Post: 17th Sep 2023, 17:00 -
Solved: Deinterlacing with QTGMC blends frames together
By PRAGMA in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2023, 03:19 -
are there any native ubuntu programs that use qtgmc with out vapoursynth?
By oduodui in forum LinuxReplies: 2Last Post: 18th Nov 2019, 13:43 -
Help with l-smash, ffms2 plugins in Hybrid and Vapoursynth for Mac (Mojave)
By celsoac in forum MacReplies: 40Last Post: 23rd Apr 2019, 19:46
