Hi everyone.
Here's my setup (for a spanish PAL tape) :
JVC S9850 > Datavideo TBC 1000 > ATI 600 USB > Windows 7 / Virtualdub
Settings : VCR = all disable (EDIT mode / PAL mode)
TBC = no settings
ATI = settings into virtualdub
1) preview
2) Capture filter : PAL_B
3) Set custom video format : 720x576 / YUY2
4) Audio : Enable audio capture / Disable audio playback
5) Audio source: Audio Line
Virtualdub = Timing : Everything disable / x Do not resynch.. / x Automatically disable resynch when integrated..
Disk I/O : Chunk size 512K - Buffer 2 - x Disable Windows write buffering
Audio is out of synch. Can't explain why.
Without the Datavideo TBC, same issue.
And colors "blinks". Good color/less colors![]()
Results 1 to 12 of 12
AmarecTV Settings
Graph 1(Device)Device Setting -> Decoder video PAL_G (*)
Recording
*w=720, h=576, fps=25,00, fcc=YUY2, bit=16
*sample=48000, bit=16, ch= 2Frame rate 999
Advanced
Video Compressor Other Codec HFYUX Wait for exit
(*) or whatever you need
Video Renderer Setting
X Auto
X Change a "HDYC" to "UYVY"
Record Setting
X Use Null frame.
X Match the start timing of the audio with a video.
X Make a report file. -
In virtualdub, try changing resync mode to
. Never had any luck with usingCode:sync audio to video by resampling the audio to a faster or slower rate
option.Code:do not resync
Well, that was a stupid detail : the usb port was defective.
The usb port on the computer box. By the way, when I put the ATI inside, the computer do a freeze !
I need to use the usb port from the card reader (for SD cards and all).
Anyway, maybe I'm wrong, but I feel AmarecTV much "lighter" than Virtualdub. -
I've found that I get choppy video on the 600 unless I disable both the video overlay and also the audio playback.
I set video to "no display" and audio playback OFF in VirtualDub. Just something else to check. -
What is the output of your VCR? PAL60?
Not expert about NTSC capture in PAL regions, but may be Hauppauge USB Live can capture NTSC.
Or try all the output combinations of the VCR versus input options of Hauppauge USB Live.
I remember I had trouble to capture from Secam with JVC HR-S9500MS (the video was too yellow!)
BTW, did AmarecTV solved the synch problems you had with VirtualDub? -
S-video output. This is an american VCR I use for NTSC tapes.
About synch problems, yes it was perfect when I captured my PAL tape.
Now I'd like to go back to NTSC settings..
Will do a new install of the drivers. See if that helps.
VHS capture (ati 600 usb , vdub, svideo, huffyuv) - needs cleaning
By TheCage in forum RestorationReplies: 27Last Post: 18th Apr 2022, 11:03 -
Anyone gotten ATI AMD TV Wonder HD 600 USB 2.0 to work on Windows 8?
By FromPartsUnknown in forum Capturing and VCRReplies: 11Last Post: 18th Sep 2019, 11:48 -
ATI Tv Wonder 600 USB can't change audio levels, Registry hack not working
By nicholasserra in forum Capturing and VCRReplies: 2Last Post: 21st Sep 2018, 21:38 -
AMD ATI TV Wonder HD 600 PAL VHS issue
By BlackCross in forum Capturing and VCRReplies: 55Last Post: 27th Feb 2018, 10:03 -
ATI 600, no padding at 352 capture, 15:11 the correct AR with 720 padding?
By jimj in forum Capturing and VCRReplies: 7Last Post: 23rd Jun 2016, 00:51
