Results 1 to 12 of 12
  1. ..
    Jan 2016
    Mar 2008
    The AmarecTV 231 on this site is a portable zip,
    just extract the files and run the executable
    https://www.videohelp.com/download/amarectv231_en.zip
    Mar 2008
    Originally Posted by Avagadro1 View Post
    davexnet:
    Thank you; this is exactly the ZIP I earlier downloaded and unzipped.
    I installed the program, but AFTER installation there is NO executable (".exe") except for the UNINSTALL.
    Even in the Windows "Start" screen, there is the AmarecTV button and thereunder an Uninstall button, but no button to open the program.
    Exactly what I found earlier.
    But thanks for the suggestion.
    It's portable - there is no install. You extract the files and run amarectv.exe
  7. Member DB83's Avatar
    Jul 2007
    There is IIRC a setting in vdub to drop video frames to keep audio in sync.
    But often sync issues are down to your PC not being able to keep up >> bad choice of video compression (which you must set BEFORE capturing else it will default to uncompressed and many systems could have issues with that)
    Mar 2008
    Some people swear by Virtualdub capture and others never get it to work - that's about the size of it
  10. Capturing Memories dellsam34's Avatar
    Jan 2016
    I use Vdub for cropping and packing to HuffYUV, not so much for capturing.
    Jan 2014
    Brisbane,Australia
    I have used the genuine EzCAP116,version 3-2A,bought from---szforwardvideo.com---since XP days and now on Win 10 also.
    Works flawlessly.
    Beware of pirates.
