Hi guys,
I have been using FCP and at times Compressor since FCP6.
I stopped using Compressor when FCP had the ability to export directly to Blu-ray HOWEVER I now need to make a Blu-ray that has uncompressed audio.
As far as I can figure out FCP does not have a way to create a Blu-ray with uncompressed audio so I exported to Compressor.
Once in Compressor, I made a “custom” setting that was Blu-ray video with .wav audio.
I “batch” and Compressor saves a separate video and audio file, then creates a .img file (which is what I want) but on playback, there is no audio, the video is there but the audio “is muted”.
Can anyone tell me...
If there is a way to do it directly in FCP?
If there is a setting or some other thing I might be overlooking in Compressor?
Does my Compressor method seem accurate, or what can I do to fix the issue?
Any help is appreciated, tia
Results 1 to 1 of 1
How to capture *UNCOMPRESSED* vhs audio+video?
By 10gigtriforce in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2020, 16:31 -
Jpeg Compressor
By yukukuhi in forum ComputerReplies: 1Last Post: 24th Jul 2016, 06:58 -
Master setting on Compressor/FCP
By shravan maurya in forum Latest Video NewsReplies: 1Last Post: 4th Jun 2016, 11:32 -
VirtualDub - Batch Convert - MP4 To Uncompressed Video With No Audio
By TheRandomOne in forum Video ConversionReplies: 5Last Post: 26th Nov 2015, 02:28 -
Cant convert DTS-HD MA audio to WAV
By monks19 in forum Video ConversionReplies: 12Last Post: 25th Oct 2015, 12:28
