UPDATE: I've tried 3 different brands of CDR media, as well as trying CDRW, just in case the DVD player wsn't liking the media I initially was using. No dice...Any help on this?
Doing some playing around tonight with various encoding schemes for testing, and I've run into the following problem (it may be that DVDR as opposed to CDR will fix this since they read differently, but I'm not sure):
(same AVI source in all cases)
352x240 MPEG1 CQ100 Max bitrate 4000 kbps. - plays fine in my DVD player.
352x240 MPEG2 CQ100 Max bitrate 7000 kbps 48khz audio (basically 1/4 D1 spec) - plays fine in my DVD player
352x480 MPEG2 CQ100 Max bitrate 7000 kbps 48khz audio (1/2 D1 spec) - audio/video stutters every few seconds
720x480 MPEG2 CQ100 Max bitrate 7000 kbps 48khz audio (full D1) - audio/video stutters every few seconds
Is there an incompatibility with using Nx480 resolutions on CDR media? I thought NTSC SVCD standard was 480x480 (which I haven't tried).
Or is the problem that I'm using a DVD template in TMPGENC and there's something in there that's choking my DVD player since the media is CDR not actually DVDR (but if that's the case, why does the 1/4 D1 video play fine)?
Too much data for the DVD player to keep up with on a CDR?
Thanks,
-Dan
Originally Posted by heavyharmonies
Not sure if it will work for you or not, but it's worth a try.
DrC -
Hmm, odd. I'll try re-encoding with the exact same specs, but 44.1 khz audio.
Since 44.1 isn't part of the DVD spec, I'm hoping this is a problem that will go away on DVDR as opposed to CDR... and had UPS not [CENSORED] up and rerouted my incoming DVD burner to Seattle instead of central Illinois, I'd be able to verify this... *grumble*
What I don't get though, is if your premise is accurate, why the 352x240 48Khz mpeg doesn't exhibit this behavior....
TMPGEnc "clip total bitrate too high for a DVD-Video" issue
By dread in forum Authoring (DVD)Replies: 7Last Post: 26th Oct 2010, 15:34 -
TMPGEnc says "clip total bitrate is too high for a DVD-Video" but it's not?
By sasuweh in forum Authoring (DVD)Replies: 24Last Post: 30th Sep 2010, 03:17 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 11:16 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
