Most VirtualDub filters can be used while capturing (if your computer is fast enough). But VirtualDub's levels filter cannot be used to recover super-blacks and super-brights in YUV video. They are crushed before the filter adjusts levels. Use the Brightness/Contrast filter instead. Even better, use the capture device's video processing amp.
The filter can sample frames from the whole video and give histogram based on the average levels.
Use that as a guide to set the levels, if anyLast edited by davexnet; 15th Aug 2020 at 23:32.
play video with histogram display, avisynth+ ?
By butterw in forum Newbie / General discussionsReplies: 44Last Post: 14th Oct 2020, 04:22 -
Capture Codec Setting, Crushed Black Levels, Histogram use
By Smells_Like_Feet in forum Capturing and VCRReplies: 8Last Post: 10th Aug 2020, 10:31 -
Red and Blue Climbing Histogram Walls
By koberulz in forum RestorationReplies: 11Last Post: 2nd Jul 2019, 09:48 -
AviSynth 'Histogram' is Suspicious
By WinUser in forum Video ConversionReplies: 13Last Post: 23rd Feb 2017, 08:49 -
Virtualdub bad encode levels
By solouplay in forum Newbie / General discussionsReplies: 6Last Post: 15th Oct 2016, 14:19
