When downloading from YouTube via YouTube-DL it's not possible to embed a thumbnail in an MKV at the moment. The best that can be done with that program is that you can download a video and a thumbnail in a separate file. Here's my script to do that:
For the MKV downloaded I then dragged it into MKV Toolnix GUI. I resized the thumbnail file to various sizes as mentioned below. I renamed the file as "cover_land" and dragged it into the attachments tab. I then clicked on "Start muxing". The resulting MKV file doesn't have a thumbnail show in Windows Explorer in Windows 7.Code:@echo off cd /D "%~dp0" setlocal enableDelayedExpansion set /p video="Paste the video link to download: " youtube-dl ^ -f ("bestvideo[width>=1920]"/bestvideo)+bestaudio/best --write-thumbnail --embed-thumbnail ^ --o "L:/VideoSharingSites/%%(title)s.%%(ext)s" ^ !video! PAUSE
When I embed any of the following:
1280 x 720 cover image (which is the size of the thumbnail downloaded) with MKV Toolnix GUI the thumbnail doesn't show in the video in Windows explorer.
1066 x 600 cover image with MKV Toolnix GUI the thumbnail doesn't show in the video in Windows explorer.
960 x 600 cover image with MKV Toolnix GUI the thumbnail doesn't show in the video in Windows explorer.
960 x 540 cover image with MKV Toolnix GUI the thumbnail doesn't show in the video in Windows explorer.
What am I doing wrong? Is there a specific dimensions I'm supposed to have for the thumbnail to show? I did what it said here but the thumbnail still didn't show: https://www.matroska.org/technical/attachments.html
Also if you're able to get it working, is there a way to add an FFMPEG command or something to my script to remux the MKV with a thumbnail while still keeping the separate thumbnail file?
Attached is the downloaded thumbnail which is 1280 x 720. I would like the aspect ratio to remain the same when the thumbnail is embedded.
[Attachment 54554 - Click to enlarge]
Do thumbnails show up on your system for any mkv files? Win7 doesn't know what MKV files are and can't show thumbnails for them unless you install a Shell Extension for MKV.
Thanks. That worked perfectly. Annoyingly YouTube-DL says it can't embed a thumbnail in the video however now I've installed Icaros, I can see that the downloaded video does have a thumbnail embedded in it but it's not the thumbnail that shows in YouTube search results so it's useless. I assume that thumbnail was made when the creator of the video made the video rather than being added by YouTube?
Anyway, the real thumbnail is still downloaded as a separate file so I still need to remux the video with the correct thumbnail in MKV Toolnix. Is there any way to automate that remuxing of the thumbnail into the MKV file? What would I need to add to my script to be able to do that? -
In your folder options make sure 'always show icons,never thumbnails' is unchecked.
Are Samsung TV’s capable of showing the thumbnail pic? And what is the size of the image supposed to be?
Thumbnail without download of complete mpeg-ts file
By iongion in forum Video Streaming DownloadingReplies: 0Last Post: 14th Aug 2020, 08:30 -
Thumbnail image for MKV files
By Steve01351 in forum EditingReplies: 1Last Post: 21st Apr 2018, 23:57 -
How can I remove custom thumbnail from mkv files?
By Gerff in forum Newbie / General discussionsReplies: 5Last Post: 11th Jun 2017, 11:12 -
Replacing thumbnail on .mkv file using mkvtoolnix or mkvmerge
By PeterProg in forum Newbie / General discussionsReplies: 17Last Post: 7th Mar 2017, 00:56 -
How to add thumbnail image displayed for MKV files?
By gringott in forum EditingReplies: 4Last Post: 19th Feb 2017, 22:02
