Any recommendations for software that I can use to trim out commercials on a Mac? Would be great if there was something that would split them and concat them losslessly.
If you want to do frame-accurate editing, you could try Smart Cutter Ps/Ts. SmartCutter Ps/Ts does smart encoding, which means that it only re-encodes incomplete GOPs containing frames on either side of the video that was removed. It has a free trial but watermarks output files while the trial is in effect.
Online trimming with FFMPEG
By danielko in forum Video Streaming DownloadingReplies: 6Last Post: 26th Oct 2019, 08:58 -
Video Trimming
By nad2cool in forum EditingReplies: 3Last Post: 27th Apr 2019, 23:48 -
Trimming a video with Avidemux
By dfisher052 in forum EditingReplies: 10Last Post: 1st Aug 2018, 13:03 -
Trimming TV Show records
By fael78rj in forum Newbie / General discussionsReplies: 10Last Post: 12th Oct 2015, 21:39 -
Trouble With Trimming Clips
By Jane4666 in forum EditingReplies: 5Last Post: 4th Sep 2015, 16:04
