  1. I have a silent (no audio track, just video) video file which is split in to three parts.
    mp4 container, total file size 1.93gb. each clip is 30fps @ 14735kbps
    I put the three parts in to DaVinci Resolve to join them together.
    I set the timeline frame rate at 30fps and then used 'change clip speed' to 15fps
    I then exported the video in mp4 limiting the data rate to 9000Kb/s with an empty audio track at 117kbps
    Am I right in thinking that the fact DV Resolve added a 'silent' blank audio track has taken the exported video up 2.36gb even tho' I have squashed the video data rate?
    Or is it because changing the speed to 15fps has doubled the length of the video?
    Mar 2008
    Has changing the speed to 15 fps doubled the runtime of the video?
    Even if it did, filesize = bitrate x runtime and fps is not part of the formula
    Look at the result in mediainfo in text view to get the details
  3. Member Cornucopia's Avatar
    If in Davinci Resolve you chose "maintain timing", the duration/running time is the same. If you chose "stretch to fit", it would (in this case) double the run time.
    Doing the math:
    Assuming you meant that the total of all original clips was 1.93 GiB (aka 16,190,013.44kb), and the overall average biitrate was 14735kbps, plugging that into the formula...
    16,190,013.44 / 14735 = 1,098.7453980319 sec (aka 18.3124233005 min.)
    Assuming your processing did modify the duration to 36.624846601 min. (aka 2,197.49079606 sec), and your video AVERAGE bitrate (not MAX - are you sure about this?) was 9000kbps and your audio bitrate was set to 117kbps (a very non-standard rate for audio!), you would do the math this way:
    2,197.49079606 sec * 9117 kbps = 20,034,523.587679 kb (aka 2.3883013234 GiB)
    This corresponds very closely with what you experienced, and given rounding, seems to match.
    Note: 2,197.49079606 * 117 = 31.3850614183 MiB (aka 0.030649474 GiB), so it is clear the audio barely contributes to the overall.
