    Aug 2020
    Seattle
    I created a .mp4 with Videopad from a dvd with an introductory menu. The mp4 had 5 minutes of intro screen (menu) and about 5 seconds of the the second chapter.
    How do I get around this problem?
    Much obliged!
    Mar 2008
    DO you want only the main movie?
    If it's commercial DVD, did you take the possible copy protection into account?
    Aug 2020
    Seattle
    Thanks, I want only the first chapter (of two). No, this is not a commercial DVD.
    Mar 2008
    Copy the video_ts folder to the HDD.
    Use vidcoder to encode, select title (if there's more than one)
    and the chapters you want included
    Aug 2020
    Seattle
    Drat, I need a ripper that works on a Mac.
    Mar 2008
    If it's not an encrypted disk, a simple file/folder copy will work.
    What is the mac equivalent of Windows Explorer ?
    It *may* work if you access the DVD directly, usually it's better to copy it first
    Aug 2020
    Seattle
    With y'alls help I did some educated stumbling into the solution! Knowing the Video_TS\vob files contained the video information, I just dble-clicked them until Voilà! I found the chapter I needed. Happy Camper!
    Thanks.
