Do the "broken" ones play in a media player without issues (e.g. vlc, mpchc, mpv... ) ?
If they play ok, it might just be an old decoder. The ffmpeg input driver for vdub classic is a few years old
Try vdub2; it contains everything you need to decode without external plugins , including newer formats like av1, hevc . ffmpeg input driver does not.
If they are "broken" in everything, then they are probably... broken -
Virtualdub2 is still being developed, the author occasionally appears in this forum to take bug reports and questions.
The original Virtualdub hasn't been touched in many years.
Use vdub2; if you have a specific issue with it, bring it to the forum here -
That is a common decoding error with long GOP, out-of-order, interframe codecs and some source filters. As you found, using a different source filter (implied by using a different program) can take care of the problem.
Problem viewing some videos on DailyMotion.com and YouTube.COM
By jimmo in forum Newbie / General discussionsReplies: 10Last Post: 20th Jun 2021, 19:24 -
virtualdub problem
By xenon1 in forum Video Streaming DownloadingReplies: 1Last Post: 13th Nov 2019, 22:18 -
Problem viewing Windows acrross extended desktop
By todsweeney in forum Newbie / General discussionsReplies: 5Last Post: 2nd Aug 2018, 11:50 -
H264 conversion problem Virtualdub
By Shadowofthedarkgod in forum Video ConversionReplies: 11Last Post: 8th Nov 2015, 14:42 -
Problem with External Encoders in VirtualDub
By XenonS in forum Video ConversionReplies: 6Last Post: 28th Oct 2015, 10:19
