Hi. I have an mkv file here with a very high bitrate so I want to encode the video but keep the original audio. Using Megui, I've indexed with both Smash and FFMS but both times I've ended up with a slightly out of sync file (I muxed the new video with the audio file extracted during Indexing).
The original mkv has perfect sync so can anyone suggest why the encodes do not?
(I thought I'd try Direct ShowSource as an Indexer but got the error "this pin cannot use the supplied media type". Maybe that's a clue to the problem?)
My thanks for any help or suggestions offered.
Out of sync in what way? Maybe you just need to set an audio delay when you mux.
Although the original mkv had perfect A/V sync, my recoded video muxed with the original AC3 audio had an A/V sync difference of 0.1 sec. I've done a further encode, this time recoding both video and audio and the result is fine. Ideally, I'd have preferred to keep the original audio but it's not a problem if I can't. But when when weird things like this happen, I just like to know 'why?...'
Regards to you both. -
The audio and video in an A/V file don't have to start at the same time, don't have to end at the same time, and don't have to have the same duration. It sounds like your source audio had a 0.1 sec delay (or advance?) but you didn't apply that same delay when you remuxed. When you reencoded both the audio and video the software compensated for the delay before encoding.
How to slightly sharp picture with ffmpeg?
By marcorocchini in forum Newbie / General discussionsReplies: 9Last Post: 8th Jun 2017, 16:16 -
Muxing of two slightly different video sources
By KennyTNT in forum EditingReplies: 1Last Post: 2nd Feb 2017, 19:59 -
is there a way to know if the MKV file i have was encoded from a DVD or...
By zanzar in forum Newbie / General discussionsReplies: 1Last Post: 22nd Aug 2016, 10:31 -
x264 slightly broken?!
By meimeiriver in forum Video ConversionReplies: 4Last Post: 3rd May 2016, 09:30 -
Need Some Help Fixing A Poorly Encoded MPEG TS File
By Robo4900 in forum Software PlayingReplies: 2Last Post: 5th Nov 2015, 10:31
