Results 1 to 20 of 20
  1. I am doing an edit/upscale restoration, working with Star Trek: Deep Space Nine DVDs. Like several shows at the time, the show was shot on film and edited on video. This results in an inconsistent pulldown cadence from cut to cut. This isn't an issue when watching it at the original broadcast 29.97fps.
    The original frame rate of the VOB is 29.97. This preserves all the frames. But so far, no matter how I demux it, import it, or convert it, it gets detelecined to 23.976fps, resulting in a lot of interlacing, or at best, reduced-quality deinterlacing and frame blending. The only way it looks right is if I play to original VOB in VLC.
    How can I convert this straight and preserve the DVD's 29.97fps without it getting detelecined?
  2. Get the video only with pgcdemux and post a mediainfo report from the m2v here
  3. Originally Posted by colonel0812 View Post
    The VOB, yes. But if shot on film that's not the 'source' framerate. An IVTC should return it to 23.976fps without the interlacing you're complaining about.
    How are you performing the IVTC? You mention 'detelecine' so maybe you're using Handbrake? Yes, a sample is needed. Me, I'd cut it from a VOB using DGIndex, 10 seconds or so with steady motion.
  4. Originally Posted by ProWo View Post
    General
    Complete name : E:\Deep Space Nine\Season 3\S03E01 The Search Part I\VideoFile.m2v
    Format : MPEG Video
    Format version : Version 2
    File size : 1.70 GiB
    Duration : 45 min 28 s
    Overall bit rate : 5 341 kb/s
    Video
    Format : MPEG Video
    Format profile : Main@Main
    Format settings : CustomMatrix / BVOP
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : Variable
    Bit rate mode : Variable
    Bit rate : 5 341 kb/s
    Maximum bit rate : 9 800 kb/s
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 (30000/1001) FPS
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.516
    Time code of first frame : 00:59:59;00
    Stream size : 1.70 GiB (100%)
    Color primaries : BT.601 NTSC
    Transfer characteristics : BT.601
    Matrix coefficients : BT.601
    Text
    Format : EIA-608
    Bit rate mode : Constant
    Stream size : 0.00 Byte (0%)
    CaptionServiceName : CC3
  5. Originally Posted by manono View Post
    Yeah, in this instance when I say "source" I'm referring to the DVD. And yeah by "detelecine" I mean IVTC. The problem is that since the show was edited on video and not on film, each edit point in the video starts at a different point in the pulldown cadence. Like this:
    [Attachment 54492 - Click to enlarge]
    The IVTC process is happening automatically no matter what I use to import or convert it. I'm trying to figure out how to NOT perform IVTC.
    I'll work up a comparison sample.
    Mar 2008
    Post a sample of the original VOB showing the transition.
    How can anybody given any advice about your workflow when you haven't stated
    anything about your program or settings?
  7. Originally Posted by colonel0812 View Post
    No one wants a "comparison sample". Just 10 well chosen seconds direct from the VOB with steady motion. If you use DGIndex to do the cutting, you'll get an M2V for upload here.
  8. Try my clever FFmpeg-GUI, rip directly from the DVD and encode with x264, CRF 23, FPS 29.97, DAR 4:4, 720x480.
  9. Okay here's a sample, and I've scaled it up and slowed it down so you can really see the interlacing.
    On the left is a 60fps screen capture of VLC playing the straight VOB file, and Codec Information says it's 29.97fps. On the right is the same VOB file imported straight into Premiere Pro, which says it is 23.976fps.
    https://youtu.be/bW8UNWLc49Y
    In VLC, deinterlacing is set to auto, turning it off results in the same artifacts as the right.
    Turning on deinterlacing in Premiere works but results in reduced quality, blended frames and transitions.
  10. Originally Posted by colonel0812 View Post
    I am doing an edit/upscale restoration.....How can I convert this straight and preserve the DVD's 29.97fps without it getting detelecined?
    You may not want to convert it straight. Depending on the restoration work you are planning you may want to double the frame rate to 59.94 which will preserve each field of the telecined material regardless of cadence.
  11. Originally Posted by manono View Post
    Ok, I'll get that.
  12. Ok see if this works.
  13. Originally Posted by smrpix View Post
    That may be exactly what I want to do. But so far nothing is preserving each field no matter what frame rate I choose, it all seems to first do IVTC.
  14. Ok I think I figured it out. In DGIndex, if I demux the entire VOB, it results in an IVTC 23.976 video. But if I trim off a few frames at the beginning, I get the straight 29.97. It solves my immediate problem, but does anyone know why that would happen?
    Mar 2008
    check video/field operation - honor pulldown flags is the normal setting.
    Are you demuxing the video for a reason? Usually, save project, then use the .d2v in an Avisynth script
  16. Ok I was wrong. When I get 29.97 it's actually sped up from the IVTC'd 23.976. This is a pain in the but, lol.
  17. Originally Posted by colonel0812 View Post
    No, it doesn't. That sample you uploaded was mostly shot on film with a few video elements in it. It IVTC's reasonably well.
    MPEG2Source("test.d2v")
    tdeintted = QTGMC(FPSDivisor=2)
    tfm(clip2=tdeintted).tdecimate()
    You still haven't said what you've been using so far, but you'll need AviSynth for a project like this.
  18. Always use DgIndex in Honor Pulldown Flags mode (except for the rare occasion when a source is 100 percent film) then IVTC (or whatever) in AviSynth.
    Your source was shot on film, telecined to 30i, then some effects were added as 30i (the shaking, for example) so it cannot be IVTC'd perfectly. It's not really noticeable at normal playback speed though (at least in that short clip).
    AviSynth Script:
    Mpeg2Source("Sample.demuxed.d2v", Info=3)
    TFM()
    TDecimate()
  19. I guess it's time to start learning AviSynth! I know nothing about it, is there a primer y'all would suggest I start with?
  20. You go to the AviSynth homepage and start reading.
    You do know, don't you, that others with more AviSynth knowledge are already deep into doing what you want to do?
    https://forum.videohelp.com/threads/396652-Deinterlacing-Deep-Space-Nine-NTSC#post2583987
    and especially:
    https://forum.doom9.org/showthread.php?t=181209
    By reading there you'll come across lots of sample scripts along the way.
