I've been using VidCoder for a few years without any major problems, when recently it no longer is able to reencode anything.
I usually convert larger mkv files to smaller mp4. Nothing has changed as far as hardware or software. The only thing I can think of is that I changed the settings to encode to h265, got distracted by something, and forgot I did so, then spent some time wondering why the conversion was taking so much longer than normal. It's possible I changed a few settings during that time (before I realised the obvious and changed back to 264), but as far as I've been able to check, the settings are no different.
The log is below for anyone kind enough to help out. Thanks.
# VidCoder 5.21
# Starting job 1/1
# Source path: G:\To Encode\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mkv
# Destination path: G:\To Encode\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mp4
# Title: 1
# Range: All
# Preset: Restored from Queue
# Worker ready: Pipe 'VidCoderWorker.3e06dde3-b9b8-444a-83bf-9b4c36bd0c88' is open
# Connecting to process 15548 on pipe VidCoderWorker.3e06dde3-b9b8-444a-83bf-9b4c36bd0c88
[13:41:37] hb_init: starting libhb thread
[13:41:37] CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
[13:41:37] - logical processor count: 4
[13:41:37] Intel Quick Sync Video support: no
[13:41:37] hb_scan: path=G:\To Encode\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mkv, title_index=1
udfread ERROR: ECMA 167 Volume Recognition failed
src/libbluray/disc/disc.c:323: failed opening UDF image G:\To Encode\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mkv
src/libbluray/disc/disc.c:424: error opening file BDMV\index.bdmv
src/libbluray/disc/disc.c:424: error opening file BDMV\BACKUP\index.bdmv
src/libbluray/bluray.c:2585: nav_get_title_list(G:\To Encode\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mkv\) failed
[13:41:37] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 6.0.1
libdvdread: Encrypted DVD support unavailable.
libdvdreadVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdreadVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[13:41:37] dvd: not a dvd - trying as a stream/file instead
Input #0, matroska,webm, from 'G:\To Encode\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mkv':
Metadata:
encoder : no_variable_data
creation_time : 1970-01-01T00:00:00.000000Z
Duration: 00:24:25.92, start: 0.000000, bitrate: 6382 kb/s
Chapter #0:0: start 0.000000, end 139.056000
Metadata:
title : 00:00:00.000
Chapter #0:1: start 139.056000, end 172.422000
Metadata:
title : 00:02:19.056
Chapter #0:2: start 172.422000, end 577.535000
Metadata:
title : 00:02:52.422
Chapter #0:3: start 577.535000, end 841.049000
Metadata:
title : 00:09:37.535
Chapter #0:4: start 841.049000, end 1377.376000
Metadata:
title : 00:14:01.049
Chapter #0:5: start 1377.376000, end 1437.978000
Metadata:
title : 00:22:57.376
Chapter #0:6: start 1437.978000, end 1465.923000
Metadata:
title : 00:23:57.978
Stream #0:0: Video: h264 (High), yuv420p(progressive), 1554x1080 [SAR 1:1 DAR 259:180], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Metadata:
BPS : 5740465
BPS-eng : 5740465
DURATION : 00:24:25.923000000
DURATION-eng : 00:24:25.923000000
NUMBER_OF_FRAMES: 35147
NUMBER_OF_FRAMES-eng: 35147
NUMBER_OF_BYTES : 1051885087
NUMBER_OF_BYTES-eng: 1051885087
_STATISTICS_WRITING_APP: no_variable_data
_STATISTICS_WRITING_APP-eng: no_variable_data
_STATISTICS_WRITING_DATE_UTC: 1970-01-01 00:00:00
_STATISTICS_WRITING_DATE_UTC-eng: 1970-01-01 00:00:00
_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
Metadata:
BPS : 640000
BPS-eng : 640000
DURATION : 00:24:24.928000000
DURATION-eng : 00:24:24.928000000
NUMBER_OF_FRAMES: 45779
NUMBER_OF_FRAMES-eng: 45779
NUMBER_OF_BYTES : 117194240
NUMBER_OF_BYTES-eng: 117194240
Stream #0:2(eng): Subtitle: subrip
Metadata:
BPS : 101
BPS-eng : 101
DURATION : 00:23:56.477000000
DURATION-eng : 00:23:56.477000000
NUMBER_OF_FRAMES: 620
NUMBER_OF_FRAMES-eng: 620
NUMBER_OF_BYTES : 18304
NUMBER_OF_BYTES-eng: 18304
Stream #0:3(eng): Subtitle: subrip
Metadata:
title : SDH
BPS : 110
BPS-eng : 110
NUMBER_OF_FRAMES: 683
NUMBER_OF_FRAMES-eng: 683
NUMBER_OF_BYTES : 19786
NUMBER_OF_BYTES-eng: 19786
[13:41:37] scan: decoding previews for title 1
[13:41:37] scan: audio 0x1: ac3, rate=48000Hz, bitrate=640000 English (AC3) (5.1 ch) (640 kbps)
[13:41:38] scan: 10 previews, 1554x1080, 23.976 fps, autocrop = 0/0/56/58, aspect 4:3, PAR 1:1
[13:41:38] scan: supported video decoders: avcodec qsv
[13:41:38] libhb: scan thread found 1 valid title(s)
Calculating bitrate - Title length: 1465.923 seconds
Calculating bitrate - Available bytes: 419430400
Calculating bitrate - Output framerate: 23.976023976024
Calculating bitrate - Container overhead: 210882 bytes
Calculating bitrate - Audio track 1 - Encoder: av_aac
Calculating bitrate - Audio track 1 - Output bitrate is Auto, will be 160 kbps
Calculating bitrate - Audio track 1 - 20000 bytes/second
Calculating bitrate - Audio track 1 - Audio data is 29318460 bytes
Calculating bitrate - Audio track 1 - Overhead is 187 bytes
Calculating bitrate - Audio size: 29318647 bytes
Calculating bitrate - Available bytes minus container and audio: 389900871
Calculating bitrate - Bitrate result (kbps): 2127
[13:41:38] Starting work at: Tue Aug 11 13:41:38 2020
[13:41:38] 1 job(s) to process
[13:41:38] json job:
"Audio": {
"AudioList": [
"Bitrate": 0,
"DRC": 0.0,
"Encoder": "av_aac",
"Gain": 0.0,
"Mixdown": 4,
"NormalizeMixLevel": false,
"Samplerate": 0,
"Track": 0,
"DitherMethod": 0
"CopyMask": [
"copy:aac",
"copy:ac3",
"copy:eac3",
"copy:truehd",
"copy:dts",
"copy:dtshd",
"copy:mp3",
"copy:flac"
"Destination": {
"ChapterList": [],
"ChapterMarkers": false,
"AlignAVStart": false,
"File": "G:\\To Encode\\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mp4.part",
"Mp4Options": {
"IpodAtom": false,
"Mp4Optimize": false
"Mux": "av_mp4"
"Filters": {
"FilterList": [
"ID": 12,
"Settings": {
"crop-bottom": "0",
"crop-left": "0",
"crop-right": "0",
"crop-top": "0",
"height": "1080",
"width": "1554"
"PAR": {
"Num": 1,
"Den": 1
"Metadata": {},
"SequenceID": 0,
"Source": {
"Angle": 1,
"Range": {
"Type": "chapter",
"Start": 1,
"End": 7
"Title": 1,
"Path": "G:\\To Encode\\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mkv"
"Subtitle": {
"Search": {
"Burn": false,
"Default": false,
"Enable": false,
"Forced": false
"SubtitleList": []
"Video": {
"Encoder": "x264",
"Level": "auto",
"Bitrate": 2127,
"TwoPass": true,
"Turbo": false,
"ColorMatrixCode": 0,
"Options": "",
"Preset": "veryfast",
"Profile": "main",
"QSV": {
"Decode": false,
"AsyncDepth": 0
[13:41:38] Starting Task: Analysis Pass
[13:41:38] Skipping crop/scale filter
[13:41:38] work: bitrate not specified, track 1 setting bitrate 160 Kbps
[13:41:38] job configuration:
[13:41:38] * source
[13:41:38] + G:\To Encode\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mkv
[13:41:38] + title 1, chapter(s) 1 to 7
[13:41:38] + container: matroska,webm
[13:41:38] + data rate: 6382 kbps
[13:41:38] * destination
[13:41:38] + G:\To Encode\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mp4.part
[13:41:38] + container: MPEG-4 (libavformat)
[13:41:38] * video track
[13:41:38] + decoder: h264
[13:41:38] + Output geometry
[13:41:38] + storage dimensions: 1554 x 1080
[13:41:38] + pixel aspect ratio: 1 : 1
[13:41:38] + display dimensions: 1554 x 1080
[13:41:38] + encoder: H.264 (libx264)
[13:41:38] + preset: veryfast
[13:41:38] + profile: main
[13:41:38] + level: auto
[13:41:38] + bitrate: 2127 kbps, pass: 1
[13:41:38] + color profile: 1-1-1
[13:41:38] * audio track 1
[13:41:38] + decoder: English (AC3) (5.1 ch) (640 kbps) (track 1, id 0x1)
[13:41:38] + bitrate: 640 kbps, samplerate: 48000 Hz
[13:41:38] + mixdown: Stereo
[13:41:38] + dither: none
[13:41:38] + encoder: AAC (libavcodec)
[13:41:38] + bitrate: 160 kbps, samplerate: 48000 Hz
[13:41:38] sync: expecting 35147 video frames
[13:41:38] encx264: min-keyint: 24, keyint: 240
[13:41:38] encx264: encoding at average bitrate 2127
[13:41:38] encx264: unparsed options: ref=1:8x8dct=0:weightp=1ubme=2:mixed-refs=0:trellis=0:rc-lookahead=10
x264 [info]: x264 [info]: x264 [info]: [13:41:39] sync: first pts video is 0
[13:41:39] sync: "00:00:00.000" (1) at frame 1 time 0
[13:41:39] sync: first pts audio 0x1 is 0
[13:43:24] sync: "00:02:19.056" (2) at frame 3336 time 12518756
[13:43:47] sync: "00:02:52.422" (3) at frame 4135 time 15518002
[13:48:32] sync: "00:09:37.535" (4) at frame 13851 time 51989437
[13:51:40] sync: "00:14:01.049" (5) at frame 20167 time 75698122
[13:57:54] sync: "00:22:57.376" (6) at frame 33027 time 123971347
[13:58:36] sync: "00:23:57.978" (7) at frame 34478 time 129418038
[13:58:55] reader: done. 1 scr changes
[13:58:56] work: average encoding speed for job is 33.848412 fps
[13:58:56] ac3-decoder done: 45779 frames, 0 decoder errors
[13:58:56] h264-decoder done: 35147 frames, 0 decoder errors
[13:58:56] sync: got 35147 frames, 35147 expected
[13:58:56] sync: framerate min 23.976 fps, max 23.976 fps, avg 23.976 fps
x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: [13:58:56] Starting Task: Encoding Pass
[13:58:56] Skipping crop/scale filter
[13:58:56] work: bitrate not specified, track 1 setting bitrate 160 Kbps
[13:58:56] job configuration:
[13:58:56] * source
[13:58:56] + G:\To Encode\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mkv
[13:58:56] + title 1, chapter(s) 1 to 7
[13:58:56] + container: matroska,webm
[13:58:56] + data rate: 6382 kbps
[13:58:56] * destination
[13:58:56] + G:\To Encode\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mp4.part
[13:58:56] + container: MPEG-4 (libavformat)
[13:58:56] * video track
[13:58:56] + decoder: h264
[13:58:56] + Output geometry
[13:58:56] + storage dimensions: 1554 x 1080
[13:58:56] + pixel aspect ratio: 1 : 1
[13:58:56] + display dimensions: 1554 x 1080
[13:58:56] + encoder: H.264 (libx264)
[13:58:56] + preset: veryfast
[13:58:56] + profile: main
[13:58:56] + level: auto
[13:58:56] + bitrate: 2127 kbps, pass: 2
[13:58:56] + color profile: 1-1-1
[13:58:56] * audio track 1
[13:58:56] + decoder: English (AC3) (5.1 ch) (640 kbps) (track 1, id 0x1)
[13:58:56] + bitrate: 640 kbps, samplerate: 48000 Hz
[13:58:56] + mixdown: Stereo
[13:58:56] + dither: none
[13:58:56] + encoder: AAC (libavcodec)
[13:58:56] + bitrate: 160 kbps, samplerate: 48000 Hz
[13:58:57] sync: expecting 35147 video frames
[13:58:57] encx264: min-keyint: 24, keyint: 240
[13:58:57] encx264: encoding at average bitrate 2127
[13:58:57] encx264: unparsed options: ref=1:8x8dct=0:weightp=1ubme=2:mixed-refs=0:trellis=0:rc-lookahead=10
x264 [info]: x264 [info]: x264 [info]: [13:58:59] sync: first pts video is 0
[13:58:59] sync: "00:00:00.000" (1) at frame 1 time 0
[13:58:59] sync: first pts audio 0x1 is 0
ERROR: Operation 'Ping' failed: System.OperationCanceledException: The operation was canceled.
at System.Threading.CancellationToken.ThrowOperationC anceledException()
at System.Threading.SemaphoreSlim.<WaitUntilCountOrTi meoutAsync>d__31.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatch Info.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.ThrowF orNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.Handle NonSuccessAndDebuggerNotification(Task task)
at PipeMethodCalls.PipeStreamWrapper.<SendMessageAsyn c>d__16.MoveNext()
at PipeMethodCalls.MethodInvoker`1.<GetResponseAsync> d__12.MoveNext()
at PipeMethodCalls.MethodInvoker`1.<GetResponseFromEx pressionAsync>d__10.MoveNext()
at PipeMethodCalls.MethodInvoker`1.<InvokeAsync>d__8` 1.MoveNext()
at VidCoder.RemoteProxyBase`2.<>c__DisplayClass36_0.< <RunOperationAsync>b__1>d.MoveNext() in C:\git\VidCoder\VidCoder\Services\HandBrakeProxy\RemoteProxyBase.cs:line 302
ERROR: Operation 'Ping' failed, encode is not running.
ERROR: Encode failed.
# Could not clean up failed file 'G:\To Encode\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mp4.part'.
System.IO.IOException: The process cannot access the file 'G:\To Encode\South.Park.S01.1080p.BluRay.x264-SHORTBREHD[rartv]\South.Park.S01E01.1080p.BluRay.x264-SHORTBREHD.mp4.part' because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileInfo.Delete()
at VidCoder.Services.ProcessingService.TryHandleFaile dFile(FileInfo directOutputFileInfo, IAppLogger encodeLogger, String reason, String finalOutputPath) in C:\git\VidCoder\VidCoder\Services\ProcessingServic e.cs:line 2280
# Job completed (Elapsed Time: 19m 00s)
Closed Thread
Vidcoder vs HandBrake
By Hippie_forever in forum Video ConversionReplies: 8Last Post: 4th Mar 2020, 16:41 -
SRT and Vidcoder
By mhhack in forum SubtitleReplies: 4Last Post: 28th Dec 2016, 21:09 -
I need help with VidCoder
By Hiacios in forum Video ConversionReplies: 6Last Post: 11th May 2016, 15:35 -
Where's Title 2? Vidcoder
By yuppicide0138 in forum DVD RippingReplies: 6Last Post: 28th Mar 2016, 08:08 -
Vidcoder Presets That May Be Useful
By Tom Saurus in forum Video ConversionReplies: 3Last Post: 9th Feb 2016, 13:07
