I usually extract video from DVDs using DVD Decrypter. This gives me untouched video that I then edit (only cut & paste type editing without anything that requires reencoding of any sort) in another program called MPEG Video Wizard DVD. I have done hundreds of videos this way with 0% issues, EXCEPT when it comes to dual layered DVDs. Whenever I have a DL-DVD, and I extract part of it (or in whole) from a dual layered disc, if any portion of the video I need to use happens to be around where the layer break was, it screws everything up. The video skips, has artifacts etc. Sometimes it does work, but after I have saved the edited video file, it doesn't play right or the sound drops out etc.
Question: First of all, why does this happen, and why does it ONLY happen to video from dual layer discs? Secondly, what is the proper way to extract video from a dual layered disc without involving any kind of quality loss, so that I can edit it afterwards in MPEG Video Wizard DVD without it acting up? The file format should be VOB or MPG without any reencoding involved. Please help.
If you could possibly suggest a straight forward and easy to use program without 5000 settings it would be swell. I don't like TMPGEnc and VirtualDub, but if there is a step by step guide that is easy to follow, in order to do what I am wanting to do, even those programs would be OK.
Thank you in advance.
Thanks for your reply. I tried it, and demuxing fixed the problem I was having with skips / sound drops, but instead created a new problem.
Now after I have edited the video, the result edits are several frames off in the finished result. The cuts are exact in the editing program, but after I export the MPG they don't come out right. This problem doesn't happen when I copy the VOBs in DVD Decrypter. So either way I do it, I get some sort of problem. Any other suggestions what I could try?
This is really frustrating, I really hate dealing with dual layered discs because I always have problems with them it seems.
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
Process for Ripping DVDs for Editing in Premiere Pro?
By GothPanda in forum DVD RippingReplies: 2Last Post: 17th Dec 2017, 22:47 -
Dual 2011 vs dual 1366 setup: video rendering
By mrjayviper in forum ComputerReplies: 1Last Post: 17th Aug 2017, 05:30 -
A question about editing (demuxing, remuxing, etc.) multiangle DVDs
By dilophosaurus65 in forum Authoring (DVD)Replies: 3Last Post: 4th Feb 2016, 19:27 -
Trouble opening/editing Canopus CDVC file on Windows 10 x64
By Killer3737 in forum Video ConversionReplies: 1Last Post: 4th Sep 2015, 08:44
