I have a 5 minute clip which I had converted to 320x240 a while back. Fast forward, where I was editing the source (1080p) and accidentally overwrotethe the original with edit.
Now I have the following:
- Unedited full length clip in low resolution (320x240).
- Edited partial length (60% of the original) clip in full HD (1080p).
Question is, is there a free program I can use the HD version as reference and upscale the full length clip? I looked into Waifu2x, however I would need an nvidia video card, which I do not want to waste money on yet unless I case see if the quality will be worth it.
Any recommendations? Yes, I tried running some free recovery tools to recover the original, looks like its gone.
You don't need an Nvidia card to use it:
http://avisynth.nl/index.php/Waifu2x#Resizers
but I don't think using it will help you all that much. From 240p to 1080p? -
waifu2x is limited to "2x"
Some of the github deep learning research projects, such as ESRGAN can train 4x models
https://github.com/xinntao/ESRGAN
https://github.com/yulunzhang/RCAN
https://github.com/thstkdgus35/EDSR-PyTorch
http://mmlab.ie.cuhk.edu.hk/projects/SRCNN.html
https://github.com/Zheng222/PPON
many more...
But it can take a long time to custom train the models. Some projects have pre-trained "generic" models that you might want to play with to test it out
Single image based algorithms tend to have temporal consistency issues, flicker. TecoGAN is supposed to help with that for video, but I couldn't get this to run
https://github.com/thunil/TecoGANLast edited by poisondeathray; 11th Aug 2020 at 00:15.
Best upscaling algorithm ?
By SomeoneNeutral in forum RestorationReplies: 16Last Post: 21st Aug 2019, 11:29 -
FPS Upscaling issue
By syrpent in forum EditingReplies: 1Last Post: 8th Apr 2019, 18:24 -
Upscaling
By DiggyDre in forum EditingReplies: 2Last Post: 16th Feb 2019, 20:42 -
Upscaling SD-video?
By bagmand in forum Video ConversionReplies: 10Last Post: 29th Nov 2017, 01:59 -
4K upscaling question
By jacatone in forum Newbie / General discussionsReplies: 4Last Post: 6th Nov 2017, 22:04
