Please see Playback Info below. I updated PotPlayer and some drivers and I fear I broke some setting or config or codec. Of note, this is just a 1080 blu ray video which my computer can handle like a champ and I played this video all the time but now after some changes seems something is broken.
See the format and graphic card being used for hardward acceleration and see the frame rate.
What setting changes do I need to make to get it play alright again?
Am I missing any codec?
[Attachment 54451 - Click to enlarge]
	Try to right click - playback - speed - normal/last used.
 Or just reset settings.
 PotPlayer use non-standard hotkeys and it's easy to brake something by mistake, so you can disable default hotkeys and create your own, just those you need.
 It's not so easy though, you have to add each one by one, so you can use these, just edit the ini file:
 PotPlayer • Custom Keyboard Shortcuts / Hotkeys
	It is not a playback speed issue, I tried that. It is a renderer/encoder/codec issue.
  Variabel frame rate / constant frame rate problem with free version of VSDCBy danielschut in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2020, 03:50
  transcode Variable Frame Rate (VFR) AVC video to Constant Frame rate (CFR)By hydra3333 in forum Video ConversionReplies: 2Last Post: 4th Mar 2018, 06:01
  Variable frame rate into constant frame rate without re-encodingBy DunnoNo in forum Newbie / General discussionsReplies: 8Last Post: 21st Dec 2017, 12:05
  Potplayer - Custom video frame output size of x0.75?By dyucca in forum Software PlayingReplies: 0Last Post: 7th Nov 2016, 05:48
  PotPlayer - Only playing part of video fileBy vicorp in forum Software PlayingReplies: 7Last Post: 1st Dec 2015, 21:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
