I'm having problems with the audio on this one movie that I have. It's in SVCD format, but I am currently trying to convert it so that I can put it on a DVD-R disc. The audio is fine when playing the original, but when I play my version the audio is out of sync. I am not a newbie and I have been encoding for awhile, but for some stupid reason this movie just doesn't wanna go. Please help me. I'm using TMPGEnc v2.53.35.130 and the machine I have is Intel P4 1.4GHz, 512 MB ram, 60GB HD, and GeForce3 64MB GFX Card.
This American system of ours, call it Americanism, call it capitalism, call it what you will, gives each and every one of us a great opportunity if we only seize it with both hands and make the most of it.
Al Capone (1899-1947) -
Not sure but could this be a framerate/video format problem. Are you converting a Pal SVCD to a NTSC DVD format (or vice versa). This would cause gradual loss of sync if not done properly.
The movie I am trying to convert is from the internet so I'm not sure what version it is, but it could be pal. How can I check this out? Also how can I fix it?
Open the file in virtualdub, the click file->file properties and it will tell you what you need to know. Then, when encoding to Mpeg, ensure you select a template with matching framerate.
Nevermind...U can close this topic. I deleted the movie already 'cause it was just to frusterating.
Audio Sync Problems
By nephesh in forum Video Streaming DownloadingReplies: 0Last Post: 12th May 2011, 09:10 -
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 10:49 -
Audio sync problems
By sticklebrick in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2007, 15:14 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 13:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 07:22
