Hi.
I'm currently using this script to convert the audio of my mkv video files. What would I need to change so that only the subtitles flagged as english remain after the conversion?
Thank you.Code:for %%a in (*.mkv) do ffmpeg -y -i "%%a" -map 0 -c:v copy -c:a ac3 -b:a 640k -c:s copy "output_%%~na.mkv"
Results 1 to 17 of 17
I think this:
but i don't have a a suitable source file handy. I expect it will only work if the subs are marked as english.Code:for %%a in (*.mkv) do ffmpeg -y -i "%%a" -map 0:v -map 0:a -map 0:m:language:eng -c:v copy -c:a ac3 -b:a 640k -c:s copy "output_%%~na.mkv"
It worked for the subs, but for some reason it duplicated both the video track and the audio track. So the new file is twice the size of the original.
try edit this: '-map 0:m:language:eng' --> change the 'm' by 's'
責任者-MDX -
Both the audio and 2 subtitles tracks are flagged as 'English", I tried '0: s:language:english', it still says no match. It's odd because it works with "0:m:language:eng", only the english subtitles remained, but the audio and video duplicated.
The report says, path to input: No such file or directory. -
instead of calling ffmpeg (with proper paths not variables) through a batch file call it in a Windows Command Prompt, copy the output (right click, mark all, copy it by right click, and paste it here)
users currently on my ignore list: deadrats, Stears555, marcorocchini -
First maybe I can try to select the subtitle track number instead of the language? What would it be in the script if the only track I need is number 4?
@jagabo: Strange, but I figured it out! I removed the extra "-map 0:v" and "-map 0:a" and it worked perfectly, no duplicates!
So the script is:
Thank you.Code:for %%a in (*.mkv) do ffmpeg -y -i "%%a" -map 0:m:language:eng -c:v copy -c:a ac3 -b:a 640k -c:s copy "output_%%~na.mkv"
Weird. When I run your batch file I get an output file with no video or audio. Only English subs and chapters.
I have ffmpeg version 4.2.2, about six months old. -
Hi! you can modify the script like this:
Code: for %%a in (*.mkv) do ffmpeg -y -i ""%%a"" -map 0 -c:v copy -c:a ac3 -b:a 640k -map 0
:0 -map 0
:1 -c
copy -metadata
:0 language=eng -metadata
:1 language=eng ""output_%%~na.mkv""
By specifying ""-map 0
:0"" and ""-map 0
:1"", you're selecting the first and second subtitle streams, respectively. I also id that to watch my series with subtitles, as I'm currently learning English and preparing for IELTS. I also use https://practicalielts.com/ielts/ultimate-ielts-guide/ to prepare better. Series is just another fun way to learn a new language.
Resize MP4 video with ffmpeg and keeping aspect ratio?
By pxstein in forum Video ConversionReplies: 1Last Post: 18th Apr 2020, 15:33 -
FFMPEG - Replacing a video stream, while keeping all other streams the same
By vandalay22 in forum Video Streaming DownloadingReplies: 4Last Post: 11th Nov 2019, 11:41 -
How to specify/map English only subs in ffmpeg
By wallywalters in forum Video ConversionReplies: 4Last Post: 9th Oct 2018, 13:04 -
Keeping subtitles in DVD conversion
By RBTO in forum SubtitleReplies: 1Last Post: 18th Jul 2016, 12:15 -
MPC always defaults to English subtitles
By Starbuck1991 in forum SubtitleReplies: 1Last Post: 10th Apr 2016, 14:08
