Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Results 1 to 18 of 18
    Aug 2013
    Scotland
    I've been trying to join two specific MP4 files but for some reason the audio on the second part of the two files goes completely mute. There are some inconsistencies between the two files, but i've tried my best to have them be compatible with each other. The first file is a HD source of a recorded tv show, but my PVR cut off the end credits because it's stupid, so i sourced those from a video sharing site, only they were of lower SD resolution, so i upscaled it to 1080p in AvsPmod and sharpened it up a little to make the two match more, oh and the frame rate was 25fps (whereas the other is deinterlaced to 50 frames) so i doubled the frame rate of the second file in ffmpeg to match (I would have done so in AvsPmod but it caused the sound to go way out of sync, most likely because it's a progressive source) No matter what i do, i just can't seem to get any sound on the credits once i join them up. I can join other videos together and not have this problem.
  2. Member DB83's Avatar
    Jul 2007
    To join two files together, both must have identical specs AND that includes the sound.
  3. Post a MediaInfo Report from both videos here.
    Aug 2013
    Scotland
    Format profile                           : Base Media
    Codec ID                                 : isom (isom/iso2/avc1/mp41)
    File size                                : 2.21 GiB
    Duration                                 : 45 min 39 s
    Overall bit rate                         : 6 917 kb/s
    Writing application                      : Lavf58.35.102
    Video
    Format profile                           : High@L5
    Format settings                          : CABAC / 5 Ref Frames
    Format settings, Reference frames        : 5 frames
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Bit rate                                 : 6 779 kb/s
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 50.000 FPS
    Bits/(Pixel*Frame)                       : 0.065
    Stream size                              : 2.16 GiB (98%)
    Writing library                          : x264 core 159
    Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Codec configuration box                  : avcC
    Audio
    Format                                   : AAC LC
    Format/Info                              : Advanced Audio Codec Low Complexity
    Codec ID                                 : mp4a-40-2
    Duration_LastFrame                       : -9 ms
    Bit rate mode                            : Constant
    Bit rate                                 : 129 kb/s
    Channel layout                           : L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 SPF)
    Stream size                              : 42.0 MiB (2%)
    Default                                  : Yes
    Alternate group                          : 1
    File size                                : 760 KiB
    Duration                                 : 26 s 224 ms
    Overall bit rate                         : 238 kb/s
    Video
    Codec ID                                 : avc1
    Duration                                 : 26 s 200 ms
    Bit rate                                 : 100 kb/s
    Bits/(Pixel*Frame)                       : 0.001
    Stream size                              : 320 KiB (42%)
    Audio
    Format                                   : AAC LC
    Duration_LastFrame                       : -15 ms
    Bit rate                                 : 128 kb/s
    Sampling rate                            : 44.1 kHz
    Frame rate                               : 43.066 FPS (1024 SPF)
    Stream size                              : 409 KiB (54%)
    Default                                  : Yes
    Alternate group                          : 1
  5. Did you account for the audio sampling rate difference? 48Khz vs. 44.1Khz ?
    Aug 2013
    Scotland
    I didn't notice the sampling rates differed, and also didn't know the specs had to be the exact same. Have changed the ar to 48Khz and now having no issue. Many thanks
    Aug 2013
    Scotland
    Rather than making another thread, i also want to know how you can trim two or more video files in the same .avs document. I must be doing something wrong as the second video doesn't trim correctly.
    SetFilterMTMode("DEFAULT_MT_MODE", 2)
    SetFilterMTMode("QTGMC", 2)
    vid=AVISource("F:\Video Files\Clip 1.avi").AssumeTFF().AssumeFPS(25).QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, Lossless=2, TR2=2, EdiThreads=2, border=true).Spline36Resize(1280,720).Trim(350,6300)
    vid2=AVISource("F:\Video Files\Clip 2.avi").AssumeTFF().AssumeFPS(25).QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, Lossless=2, TR2=2, EdiThreads=2, border=true).Spline36Resize(1280,720).Trim(6350,13580)
    vid ++ vid2
    Prefetch(5)
  8. Originally Posted by Master Tape View Post
    vid ++ vid2
    Prefetch(5)
    In what way is it "not correct" ?
    If the frame numbers are incorrect (wrong frames returned), recall that the frame numbers refer to double rate (50p) numbers , because it's applied after QTGMC.
    Aug 2013
    Scotland
    vid ++ vid2
    Prefetch(5)
    Well for the duration of the second clip (after i apply the trim) it's just showing the final frame and nothing else.
  10. Does "vid" or the 1st part display correctly?
    what does vid2 alone return ? Disable multithreading , everything else. Just check if this works
    Aug 2013
    Scotland
    Yes the first part is working fine, though it cuts off at frame 5950 rather than 6300, then just crashes into the final frame of the second clip and stays there. Though i trim it at frame 350 at the start and 6300 minus 350 is 5950 interestingly.
    Getting the same result when the second clip is on it's own, though i should note i'm working with decoded avi files that were decompressed from mp4's to get it to work properly in AvsPmod, so when using QTGMC, once the video ends in AvsPmod, it's only halfway through the timeline then for the second half just displays the last frame of the video continuously, so i always have to trim that section out before rendering.
  12. Originally Posted by Master Tape View Post
    Why couldn't you get mp4's to work ?
    Check each clip alone without any filters
    I would start over with the mp4's . Do they play correctly in a media player like mpchc, vlc etc... ? Or do they have problems to begin with ?
    Aug 2013
    Scotland
    The reason i use avi's is because the mp4's give me nothing but problems and i couldn't get them to play correctly after rendering.
    Yes the mp4's play fine in the media players with no issue. Right now i can't get them to load using LSMASHVideoSource.
    [Attachment 54491 - Click to enlarge]
    As for the avi's, i previewed them on their own without any of the filters added and they just play like they do in vlc, ect, twice as fast to the end halfway through then just displays the last frame for the second half. Though it's fine for editing single clips, and just trimming out the dead space and the rendered file plays perfectly.
  14. Originally Posted by Master Tape View Post
    Are you using a current version ?
    https://github.com/HolyWu/L-SMASH-Works/releases
    What does mediainfo (view=>text) say about one of the mp4's (copy/paste the text back here)
    Try LWLibavVideoSource("video.mp4")
    Or try ffms2. Use a current version such as this
    https://forum.doom9.org/showthread.php?p=1906345#post1906345
    FFVideoSource("video.mp4")
    That's a problem.
    If the original MP4's play fine in media players, everything should just work
    Aug 2013
    Scotland
    [QUOTE=poisondeathray;2591882]
    No, but downloaded the latest version and still had issues with the sound being in sync on the second clip.
    File size                                : 238 MiB
    Duration                                 : 2 min 13 s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 15.0 Mb/s
    Description                              : AverMedia_er130_001.001.003
    Encoded date                             : UTC 1970-01-01 00:00:00
    Tagged date                              : UTC 1970-01-01 00:00:00
    Writing application                      : Lavf53.3.0
    Comment                                  : Quality_BEST
    Video
    Format profile                           : High@L4.1
    Format settings                          : CABAC / 2 Ref Frames
    Format settings, Reference frames        : 2 frames
    Codec ID                                 : avc1
    Bit rate                                 : 14.9 Mb/s
    Scan type                                : Interlaced
    Scan type, store method                  : Separated fields
    Scan order                               : Top Field First
    Bits/(Pixel*Frame)                       : 0.144
    Stream size                              : 236 MiB (99%)
    Audio
    Format                                   : AAC LC
    Duration                                 : 2 min 12 s
    Bit rate mode                            : Variable
    Bit rate                                 : 128 kb/s
    Stream size                              : 2.03 MiB (1%)
    Default                                  : Yes
    Alternate group                          : 1
    Getting great results with FFVideo. Just remembered how to return a value, in this case "vid2" to work on it separately. The trims were all wrong because the two videos were being joined, and so was declaring the wrong frames on clip2. Very pleased with the outcome of the video, but having problems with the audio. Whilst the video plays fine, the audio plays as it would unedited, so everything is all out of sync. How do i get the trims to apply to the audio aswell?
    vid = FFVideoSource("F:\A Video Files\Clip 1.mp4").AssumeTFF().AssumeFPS(25).QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, Lossless=2, TR2=2, EdiThreads=2, border=true).Spline36Resize(1280,720).Trim(350,6300)
    aud = FFAudioSource("F:\A Video Files\Clip 1")
    vid2 = FFVideoSource("F:\A Video Files\Clip 2.mp4").AssumeTFF().AssumeFPS(25).QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, Lossless=2, TR2=2, EdiThreads=2, border=true).Spline36Resize(1280,720).Trim(380,6400)
    aud2 = FFAudioSource("F:\A Video Files\Clip 2.mp4")
    vid ++ vid2
    AudioDub(vid,aud) ++ AudioDub(vid2,aud2)
    Prefetch(5)
  16. Originally Posted by Master Tape View Post
    What was the fps returned for the video only ? It says 50fps in mediainfo
    Does using fpsnum=25, fpsden=1 help ?
    LSmashVideoSource("video.mp4", fpsnum=25, fpsden=1)
    vid ++ vid2
    Prefetch(5)
    ffms2 has a helper function FFMpegSource2() which returns video and audio, so you can trim the video and audio together. It's a shortcut for applying AudioDub before applying Trim
    vid = FFMpegSource2("F:\A Video Files\Clip 1.mp4", atrack=-1).AssumeTFF().AssumeFPS(25).QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, Lossless=2, TR2=2, EdiThreads=2, border=true).Spline36Resize(1280,720).Trim(350,6300)
    vid2 = FFMpegSource2("F:\A Video Files\Clip 2.mp4", atrack=-1).AssumeTFF().AssumeFPS(25).QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, Lossless=2, TR2=2, EdiThreads=2, border=true).Spline36Resize(1280,720).Trim(380,6400)
    vid ++ vid2
    Prefetch(5)
    Aug 2013
    Scotland
    I think MediaInfo is declaring the fields as frames. It's 25fps, so 50i PAL.
    No change at all, and i had to half the number of frames in my trims to get it in the correct places.
    vid ++ vid2
    Prefetch(5)
    Many thanks, that fixed it! Plays perfectly with sound all in sync.
  18. Member
    Aug 2013
    Scotland
    Back to joining files and it has happened again. Only this time i can see no differences between the three files (basically i cut out segments from one long video clip and want to rejoin them) so they are essentially from the one file so should all have identical specs.
    Video
    Format profile                           : High@L3.1
    Format settings                          : CABAC / 6 Ref Frames
    Format settings, Reference frames        : 6 frames
    Codec ID                                 : avc1
    Duration                                 : 9 min 0 s
    Bit rate                                 : 1 485 kb/s
    Width                                    : 896 pixels
    Height                                   : 504 pixels
    Frame rate mode                          : Variable
    Frame rate                               : 25.000 FPS
    Minimum frame rate                       : 12.500 FPS
    Maximum frame rate                       : 25 000.000 FPS
    Bits/(Pixel*Frame)                       : 0.132
    Stream size                              : 95.6 MiB (93%)
    Audio
    Format                                   : AAC LC
    Bit rate                                 : 96.0 kb/s
    Stream size                              : 6.11 MiB (6%)
    Default                                  : Yes
    Alternate group                          : 1
    Video
    Codec ID                                 : avc1
    Duration                                 : 29 min 24 s
    Bit rate                                 : 1 493 kb/s
    Width                                    : 896 pixels
    Height                                   : 504 pixels
    Stream size                              : 314 MiB (93%)
    Audio
    Format                                   : AAC LC
    Stream size                              : 20.1 MiB (6%)
    Default                                  : Yes
    Alternate group                          : 1
    Video
    Codec ID                                 : avc1
    Duration                                 : 8 min 54 s
    Bit rate                                 : 1 466 kb/s
    Width                                    : 896 pixels
    Height                                   : 504 pixels
    Bits/(Pixel*Frame)                       : 0.130
    Stream size                              : 93.3 MiB (93%)
    Audio
    Format                                   : AAC LC
    Stream size                              : 6.14 MiB (6%)
    Default                                  : Yes
    Alternate group                          : 1
