Hi!
I'd like to buy a laser disc player which can read US imports (NTSC zone 1 I guess) and also japanese ones.
Is the latest Pioneer DVL 919 specific for this?
I'm looking for a japanese one at basis but not sure if it can also read US import zone 1 NTSC discs.
Thanks!
Results 1 to 9 of 9
There are no Regions or Zones for LD's. They're either NTSC or PAL and will playback on any appropriate player.
The exception are MUSE HD LDs that require a special MUSE player HLD-X0 and HLD-X9 that were only released in Japan and while considered the best LD players are extremely expensive.
The DVL-919 is considered a good LD player, but like all electronics 20+ years old, there may be mechanical issues and dried out capacitors, so buy from a highly rated seller and have a good return window if it doesn't work correctly.
If you want more info, I suggest you go to forums at lddb.com as there's only a handful of members here who discuss LD here. -
Thinking about it, curious as to why do you want a LD player? The vast majority of LDs, with the notable exception of the original Star Wars Trilogy have been released of DVD or Blu-Ray somewhere in the world. A week or so ago, I posted how a movie that I've only had on VCD (I'm not even sure it was released on LD) was recently released on Blu-Ray and DVD. Waiting for it to arrive.
LDs don't have zones. They do have systems, so either read NTSC or PAL (don't think there was ever a player that did both). US and Japan are both NTSC.
(Sorry so late, post got delayed)
Scott -
No dual system player and AFAIK, no SECAM player either. LD wasn't a big seller in Europe or the U.S. for that matter. It was very popular in Japan, though I think with the exception of some Karaoke players and the MUSE players, everything came to the U.S. via Pioneer or high end manufacturers.
If you can lay your hands on the european model DVL-919E I think you're good to go:
https://hometheaterreview.com/pioneer-dvl-919e-laserdisc-and-dvd-player-reviewed/
quote "...this player is intended for the European market, hence its dual-standard PAL+NTSC laser disc capability and Region Two DVD..." \quote -
Thanks to all for your infos!
Can the DVL-919 do CLV & CAV? Also what about the subtitles? I read about the Pioneer ones do not need any adapters...
>Lingyi: SW theatrical would be enough eason to buy an LD to my opinion. But there are more productions never released on DVD or BR. For exemple, the DBZ OAVs does effectively have a japanese DVD (maybe BR) releases but their cover arent illustrated by Toriyama (only a sample of the genuine illustration is printed on the back of the cover). Also, the LD's does have original year manufatures (same year that the OAV releases). So, they are original goods. More, there are some theatrical releases (for example THX 1138 I guess...) which are only released on LDs. They are more beautiful goods for japanese OAV lovers.
Btw, you said that the DVL-919 is +20yo but after wiki it was manufactured on 2009...
>Lennio: I'd prefere a japanese one since to me its important to have an anthentic product, I don't neither like european versions of DVD/BR for examples, same for books, etc...Last edited by erzane; 7th Aug 2020 at 10:19.
@ennio
Thank you for the correction. Never heard about the DVL-919E. Guess it was a last attempt by Pioneer to keep the market alive.
Getting a Japanese player may be a bit easier and cheaper as they seem to be a bit more common on eBay.
@erzane
Yes, 2009 was the last date of manufacture of the DVL-919. Misread and misremembered the date since I had my LD players in the early '90's.
And yes, all players are capable of CLV and CAV playback, as well as subs which are hardsubbed because LD is an analog format.
Because LD is analog, you may want to consider getting a second player, different model (e.g. The Elite series) as some do better than others with certain discs. Again, best ask at the lddb.com forum. avsforum.com also has/had a LD forum.
Video grabber to use on a laser disk
By xenon1 in forum Authoring (DVD)Replies: 7Last Post: 14th Jul 2020, 18:48 -
2 Blu Ray Discs, 1 srt subtitle file, do I have to rip and merge both discs
By sethhuner in forum Blu-ray RippingReplies: 5Last Post: 27th Jun 2020, 10:24 -
laser to mp4 file problem
By xenon1 in forum Newbie / General discussionsReplies: 11Last Post: 16th Jun 2020, 18:46 -
How can the DVD laser trimmer be adjusted easily?
By TechLord in forum Newbie / General discussionsReplies: 1Last Post: 9th Sep 2017, 18:09 -
Samsung Laser Printer
By cornemuse in forum ComputerReplies: 12Last Post: 28th Jan 2017, 09:27
