I have some MP4 files that have subtitles. When I burn them to DVD using Wondershare DVD creator it loses the subtitles.
Is there any software that will burn the DVD and keep the subtitles.
Wondershare is crap.
The subtitles are a separate sub stream, and must be converted to the DVD-Video spec sub stream format.
It can be done, yes.Want my help? Ask here! (not via PM!)
If not hard-coded (an always-visible part of the actual video), the subtitles in MP4 (and MKV) video files are stored as separate streams. Depending on the specific MP4 and subtitle specs, a DVD creation app may or may not recognize there is a subtitle stream and automatically import it into your DVD conversion. More often than not, you need to either download a matching .SRT file from one of the subtitle enthusiast websites, or extract the subtitle from the MP4 with a utility like mkvToolnix. You then import the separate subtitle file into your DVD project with the subtitle controls in your DVD authoring app (AVS2DVD, DVDflick, DVDstyler, etc). You should be able to choose how you want the subtitle to work: automatically show whenever the DVD plays, or not show unless you press the subtitle display button of your DVD player.
How to easily burn in/hardcode srt subtitles to mp4/mkv with VidCoder
By Baldrick in forum User guidesReplies: 65Last Post: 25th Jun 2024, 03:11 -
Adding Subtitles to MP4 Files
By elapid in forum SubtitleReplies: 13Last Post: 26th Nov 2015, 20:58 -
How to AHD Subtitles Maker Open FLV and MP4 Video Files Directly?
By devilcoelhodog in forum SubtitleReplies: 2Last Post: 22nd Nov 2015, 10:00 -
How to Burn DVD using .mp4 file ( No Encoding )
By Aashik Alam in forum EditingReplies: 1Last Post: 24th Oct 2015, 03:38
