I have a CSV whose contents I want displayed per frame in the video, in this case a number indicating the audio delay in milliseconds so I know exactly where the problem is getting worse as I'm browsing the video.
How do I do this?
Thanks.
Do you have an entry per frame ?
Maybe convert it to a subtitle format
or
Maybe conditionalreader in avsiynth with scriptclip and subtitle . There is an example on this page
http://avisynth.nl/index.php/ConditionalReader -
An entry per frame, yes. I have 150,000 number values in a CSV file separated by new lines, first one for frame 0 and last one for frame 150,000.
Do I understand that to make this work in conditionalreader I would have to prepend the values with R 1 1, R 2 2, R 3 3 etc. to make it work? -
You don't need "R" . "R" is to specify a range of more than 1 frame; you don't have a range - each frame already has an entry in your case
You just need to prepend a frame number to each entry
But if you wanted to reduce the filesize or number of entries in the text file, you could use R . e.g. if a range of frames had the same delay value, you can group them into rangesLast edited by poisondeathray; 6th Aug 2020 at 11:48.
Best software for text editing frame by frame?!
By lolcox in forum EditingReplies: 8Last Post: 30th Jun 2018, 07:47 -
Artifacts after changing the parameters of the frame
By Megafox in forum Newbie / General discussionsReplies: 6Last Post: 11th Feb 2018, 07:47 -
YouTube keep changing frame rate
By kodec in forum Video Streaming DownloadingReplies: 23Last Post: 25th Jul 2017, 14:03 -
Changing text color in watermark
By okizen in forum Video ConversionReplies: 5Last Post: 3rd May 2016, 08:53 -
VirtualDub displaying blocky video and text
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 7th Feb 2016, 22:07
