Hi,
I have a question about "MSU Frame Rate Conversion Filter".
For several days I have been trying to convert my movie from 30 to 60 FPS in the MeGUI program. I can't do this. You will get an error every time.
Does anyone in you have any vdf plugin for VirtualDubMod to be able to do it correctly in this program?
If you can give any coding example it would be great
Maybe I keep making mistakes when typing my code?
Tomek
Results 1 to 1 of 1
Variabel frame rate / constant frame rate problem with free version of VSDC
By danielschut in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2020, 03:50 -
Frame rate conversion
By ostatak in forum Video ConversionReplies: 0Last Post: 16th Aug 2019, 15:47 -
transcode Variable Frame Rate (VFR) AVC video to Constant Frame rate (CFR)
By hydra3333 in forum Video ConversionReplies: 2Last Post: 4th Mar 2018, 06:01 -
Advanced Frame Rate Conversion: After Effects AVISynth VideoEnhancer Plugin
By Tom4 in forum EditingReplies: 24Last Post: 9th Nov 2017, 00:18 -
Frame Blend Frame Rate Conversion with Scene Change Detection
By ndjamena in forum RestorationReplies: 7Last Post: 3rd Nov 2015, 10:26
