hmmm, can't get anything to work. All I get when I click on YUY2 is the message: unsupported video format. This happens on all the choices. Any suggestions? Thanks
Results 61 to 66 of 66
hello ! im having some issues with my capturing.... at some point in the captured video, a white box appers in the middle, it takes about 60% of the screen in the middle... i try using vdub 1.6.6 and vdub 1.5.10, with no compression or with picvideo mjpeg, with nvidia and microsoft wmd drivers ... all the combinaisons gave me the same problem ... i have a msi fx5600 vtdr128 vid card .. anyone got solutions ? thx
This was posted using a bugmenot account.
Try using the WDM 1.08 capture drivers from nVidia, they will help with this issue. You might need to use an older Forceware driver like (71.xx or earlier) - but try it with WDM 1.08 alone first. -
Hello
i am actually looking to capture raw frames without interlacing.
is there a way to turn off interlacing in virtualdub.
please help
thank you
L. -
Interlacing isn't caused by VirtualDub, it's the native state of video. If you want to deinterlace while capturing enable filtering (Video -> Filter Chain -> Enable) and add the Deinterlace filter (Video -> Filter Chain -> Filter List). But you run the risk of dropping frames (as the deinterlacing requires more CPU resources) and you will be damaging your captures.
Just wondering if theres an updated how to guide "High Quality Capturing with Little Frame Loss in VirtualDub", or is this even still the best way to transfer VCR tapes?
Stop Motion Animation Frame by Frame Capturing
By Fary4u in forum Capturing and VCRReplies: 9Last Post: 5th Jan 2012, 16:49 -
FLV Input Plugin for Virtualdub lets you save as AVI with no quality loss?
By gumbygum in forum Video ConversionReplies: 7Last Post: 1st Aug 2010, 14:08 -
capturing high-quality streams
By topquark in forum Newbie / General discussionsReplies: 0Last Post: 24th Apr 2010, 01:12 -
Virtualdub or Avidemux better to cut FLVs with no quality loss?
By gumbygum in forum EditingReplies: 17Last Post: 28th Nov 2009, 10:13 -
Snappy Video Snapshot Inner Workings / High Quality Frame Grabs
By acid_burn in forum Capturing and VCRReplies: 2Last Post: 6th Mar 2008, 00:11
