Hi,
I need to get direct vocal audio to the camera.
I have Shure 58s and some similar mics but not sure how to connect. The 53 only has the mini jack while the 58 etc use a Canon.
Without having to go to a lot of expense what is the best way to do this please.
oz
You need a camera adapter. Beachtek makes good and popular ones. You can also loop through something like a Zoom recorder. Direct XLR to mini adapter cables do not work.
(And your subject line appears to misidentify your Sony Camera as a Canon -- but I don't think that's what you mean.) -
Thank you.
Will check out that unit and others. I was hoping I didn't have to go to more expense with yet another gizmo
I apologize, yes I did mean Sony.
oz -
I eventually bought the ...
IK Multimedia iRIG Pre Microphone XLR Interface for IOS device iphone ipad andriod camera
It comes with great reviews so we'll give it a whirl.
Can I capture old Hi8 to my Sony FDR AX53
By ozstar100 in forum Capturing and VCRReplies: 0Last Post: 2nd Jun 2020, 23:51 -
[XLR mic] Imune from cellphone signal? Entry level mic?
By yetanotherlogin in forum AudioReplies: 17Last Post: 6th Jan 2019, 12:46 -
Help for begginer - Whats best (recommend) XLR Mic for Canon XF105 cam?
By dean79 in forum Newbie / General discussionsReplies: 2Last Post: 30th Nov 2016, 09:10 -
Stereo mic - or any external mic work on Kyocera Hydro Elite Android phone?
By brassplyer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Nov 2016, 20:08 -
Recording in XAVC S HD on Sony FDR-AX53
By Gil T Remnant in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Oct 2016, 13:41
