Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. Hi,
    I have about a thousand .flv files, the size of each of which varies from 1 GB to 11 GB. I don't want any file to be bigger than 512 MB, and thus, I would like to split all of these files into smaller pieces, without any re-encoding. Is there any tool that allows me to do so?
    What I would like to do is select all the files, enter the size that I want each part to be of (512 MB), and just batch split all of them in one go.
    Below are the details about one of the video files:
    From MediaInfo:
    General
    Complete name : G:\Streamlink\142912.flv
    Format : MPEG-TS
    File size : 10.6 GiB
    Duration : 4 h 46 min
    Overall bit rate : 5 297 kb/s
    FileExtension_Invalid : ts m2t m2s m4t m4s tmf ts tp trp ty
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4
    Format settings : CABAC / 1 Ref Frames
    Format settings, CABAC : Yes
    Format settings, RefFrames : 1 frame
    Format settings, GOP : M=1, N=15
    Codec ID : 27
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 30.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Audio
    Menu ID : 1 (0x1)
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Muxing mode : ADTS
    Codec ID : 15
    Bit rate mode : Variable
    Channel(s) : 2 channels
    Sampling rate : 44.1 kHz
    Frame rate : 43.066 FPS (1024 SPF)
    Compression mode : Lossy
    Delay relative to video : 6 ms
    Image Attached Images
    Aug 2020
    Randallstown, MD
    What is the reason for the split?
    Do you want independently playing pieces, or do you simply want individually sized pieces that can be later recombined into its original self?
  3. Originally Posted by therube View Post
    Thanks for taking the time to reply. The reason is that these files are huge live streams, downloaded using Streamlink. I wanted all the parts to be playable independently. I am constantly uploading these to a cloud storage service called Degoo, which doesn't allow its free users to upload files larger than 512 MB. In addition, having smaller and equal sized parts makes it easier to organize them and to find any specific part from the downloaded streams that I am looking for.
    I have already found a solution in another post.
  4. You can use mkv merge. Just add in the file size for the split.
  5. Member Cornucopia's Avatar
    You'll have to split them on keyframes if you want to avoid re-encoding. And that means they very likely WON'T be the exact same filesize, as it will be content- (read: bitrate) dependent.
