Im editing on Sony Vegas and I want to listen to music in Youtube for instance, and sometimes I lose audio on Youtube, or on Sony Vegas, and I have to change the audio settings in Vegas from one thing to another (not sure what these do, I just change it to something else so it works again)
On my animation software I lose sound and I have to close it and open it again. Sometimes I get an error:
Anyone had this problem and how to fix it?
Make sure you select the correct audio device in Control Panel.
Then, without Vegas open, make sure you can play audio from YouTube in your browser (I assume that is how you are playing YouTube).
Finally, once that is working, go back to Vegas, and change the audio device in the dialog you posted until you get audio in Vegas. That setting should make zero difference to the audio device being used to play YouTube in your browser.
If you have an audio card that has installed its own software (Creative Labs devices often do this), then you may also need to look at the setup apps for that sound card when doing the first two steps above. -
Does the audio stop working suddenly and randomly, or while doing a particular action ?
Could it be caused by some keyboard shortcut accidentally activated ? -
he actually has vegas 16, not 13.
[Attachment 55455 - Click to enlarge]--
Rendering Problems in Sony Vegas Pro
By CaptainCatholic587 in forum EditingReplies: 7Last Post: 22nd Apr 2020, 02:33 -
Sony Vegas Sharpen Plugin....Vegas 10 amazing, Vegas 11 terrible?
By Blackout in forum RestorationReplies: 3Last Post: 16th Feb 2020, 13:48 -
Sony Vegas 13 only importing audio and no video
By OmegaAlphaGaming in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2016, 10:45 -
Sony Vegas / Adobe After Effects (transparency problems with overlay)
By deadlys in forum EditingReplies: 3Last Post: 16th Feb 2016, 21:01 -
How to Keep Multiple Audio Streams in Sony Vegas Pro 13 ?
By kwanami in forum EditingReplies: 10Last Post: 14th Oct 2015, 14:41
