I'm using AviSynth to change my video from VFR to CFR. I want to use it with another application that doesn't have AviSynth support, so I installed AVFS and created a file server. The problem is that when playing the served file, the video is garbled, but when playing the AVS script (even the one output by AVFS), it looks perfectly fine.
Here's the AVS:
Here's what the video looks like when I play the AVS script in any software that supports AviSynth:Code:LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\ffms2.dll") FFVideoSource("D:\Videos\Tools\Interpolation\tmnt.mkv", fpsnum=30000, fpsden=1001, threads=1)
[Attachment 54334 - Click to enlarge]
Now here's what the served AVFS file looks like when I play it in any video software:
[Attachment 54335 - Click to enlarge]
What's especially strange about this, is if I pause the video, it will constantly blink between two color variations, and it does not do this while playing the video.
Here's the AVFS error log:
Does anyone know what might be going on here? Again, there's nothing wrong with the AVS script itself, since it plays fine in every software that supports AviSynth. It seems to be some issue in the file serving process. Thanks for any help you could give.Code:Video stream :- Duration: 1813 frames, 00:01:00.493 ColorSpace: YV12 Width: 706 pixels, Height: 478 pixels. Frames per second: 29.9700 (30000/1001) FieldBased (Separated) Video: No Parity: Bottom field first. Field order: Assumed Bottom Field First No audio stream. AvfsWavMediaInit: Clip has no audio.
706x478 - Probably the dimensions need to be mod 4 (evenly divisible by 4) for your other program to upsample and display the 4:2:0 data correctly
Either crop or pad the dimensions to mod4; or if keeping those dimensions - use a different pixel format such as YUV444 , or RGB . Many programs do not support YUV444
AVS scripts opened by VirtualDub but no video with AVFS
By abolibibelot in forum Video ConversionReplies: 24Last Post: 27th Nov 2018, 20:16 -
Creating AVS script in MeGui . .
By Manxsee in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2018, 11:31 -
why AVFS don't load AVS's script that contain 64bit plugin?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2017, 06:58 -
How to resolve some errors with avs script?
By robusco in forum Video ConversionReplies: 12Last Post: 4th Dec 2015, 12:37 -
Video exported with pinnacle16 :image plays then freezes audio plays fine
By RonWolpa in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2015, 17:00
