  1. Member zoobie's Avatar
    Feb 2005
    Florida
    Yep...it's a mono 1/8 double plug but there's also a little hole on the end. Came across this...wondering what it is...what it's used for
    See attachment...
  2. Probably a dual mono to stereo adapter.
  3. Member zoobie's Avatar
    Feb 2005
    Florida
    The fixed width looks like it would plug into the rear audio outlets...It would need a micro stereo plug I guess
  4. Member darkknight145's Avatar
    Feb 2007
    Australia
    It's a converter from dual mono to stereo jack. These are commonly used on aircraft seat entertainment systems that have the headphone jacks on the seat arm rest. They allow you to use your own headphones.
    canada
    Just changed your thread title so you can get more help.
  6. Hey, I've been looking all around for that. It's the mate to this thing that is in the junk box two feet from where I'm typing this.
    canada
    I dont think it's a mate for it since if you plug in the dual pins in it will be another bridge that's not needed,plug a 3.5 male end into the op's plug and connect the pins.
  8. Member darkknight145's Avatar
    Feb 2007
    Australia
    The image that "johnmeyer" posted is a headphone splitter, allowing you to run two headphones from the same socket.
